96 EVO 80 using oil
Old Aug 26, 2025 | 03:21 PM
randallissimo's Avatar
randallissimo
Default 96 EVO 80 using oil
42K miles. This bike runs great, although it doesn't pull for ****. Rode 4.5K miles in June on a round trip from Florida to Maine without much issue. Except that it uses oil, maybe a quart every 1000 miles or something like it. It doesn't leak, doesn't smoke, and doesn't have the power it should I don't think. Whenever I check the oil it is on the low side. I add some, but don't want to mistakenly overfill, so I go easy when I do. I check it cold and hot, it always looks low. And black, too. I can change the oil and it will be black in two days. My rebuilt 95 EVO 1250 Sporty oil looks clean for quite a while.
It has an Andrews cam, I assume no. 27 based on what was the thing to do back in the 90s, meaning the valve springs were probably not changed. Also has Screaming Eagle baloney slash pipes, and some sort of intake set up built around a K&N round filter and the stock cover, which I like.
Compression sits at 135 and 137 psi Everything I read says 150 psi or more is what you want, the manual says over 90 is considered normal. Haven't done a leak down test yet, but I plan to.
So, what am I looking at here? Maybe time for a valve job?
Old Aug 26, 2025 | 03:45 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
What model bike?
If you are overfilling the oil tank the excess oil will blow out the breather until it reaches it`s proper level.
Oil color is not a good way to determine an engines condition.
Those compression test numbers are not terrible.
Keep in mind compression tests and leakdown tests only show what the engine is doing when it is not running, the compression may be fine when the engine is running.
If you don`t hear any leakage past the valves when you do the leakdown test, I suggest you keep riding it.
However, if you decide to tear the engine down, a reputable Harley machinist can evaluate your components and tell you what you need.
Old Aug 26, 2025 | 03:46 PM
Racepres's Avatar
Racepres
Adding oil Hot or Cold Engine??
Half full is Plenty BTW...I consider 3/4 to be Full!! Even the Manual says..."between the marks" !!
RDHIGH's Avatar
RDHIGH
If youre not burning it (it will show on your plugs after a while)- you are either blowing it out your breather- or it could be migrating to your primary.
next time you think its low- pull off your derby cover, and see if its overfull.
If it is- now you know where your oil is going...
Old Aug 26, 2025 | 09:11 PM
Joe12RK's Avatar
Joe12RK
Is your breather hose going to the air filter or did you divert it to the ground?
Old Aug 27, 2025 | 02:14 AM
randallissimo
Good points.
Breather hose goes to ground, but I don't see evidence of much oil spray. Pretty sure if it was going in the primary, I'd have seen it by now since I have been in there replacing the clutch not too long ago. And it would have to explain for a lot of oil given how much it disappears.
Bike is a 96 Dyna FXD 80
Old Aug 27, 2025 | 06:07 AM
Architect's Avatar
Architect
My 1997 Dyna Wide Glide with +40k miles does the same thing with the black oil. I can change it with new filter, within 500 miles it is black again. I theorize the rings might be getting old etc. But I do not have oil loss issues nor does she blow smoke. With the Andrews EV27 cam and a Mikuni, she is a real ripper even with my (gasp) drag pipes!!!!
I have spoken to several real mechanics about the black oil, they all tell me to leave her alone if she is running well, which she is and plugs are perfect. Good luck to all of us.
Old Aug 27, 2025 | 06:08 AM
Bubba Zanetti's Avatar
Bubba Zanetti
How do the plugs look?
Old Aug 27, 2025 | 06:56 AM
Racepres's Avatar
Racepres
On Pump Gas??? Black!!
bagga
EVO
31
Aug 26, 2017 08:25 AM
u wish u could ride
EVO
Jun 9, 2013 06:32 AM
rds1778
Exhaust System Topics
18
Aug 7, 2011 05:13 PM
the blob
EVO
11
Nov 2, 2010 07:52 PM
mayfiebl
11
Oct 5, 2007 08:06 AM
