Fuel line on 1998 FLHTCUI
Old Apr 2, 2026 | 11:14 AM
evotrike's Avatar
evotrike
Default Fuel line on 1998 FLHTCUI
How do I remove the return fuel line at the top of the injector body?
No bolt head I can see.
Manual not clear on procedure.
Old Apr 2, 2026 | 09:47 PM
evotrike's Avatar
evotrike
Got it figured out.
So dusty I could not see little circlip.
Old Apr 2, 2026 | 10:00 PM
im's Avatar
im
Correct.
They have tendency to fly away or fall and hide too.
Old Apr 2, 2026 | 10:13 PM
HarvHD's Avatar
HarvHD
As you figured out, small circlips. Much easier access with the tank out of the way.
Old Apr 4, 2026 | 04:39 PM
evotrike's Avatar
evotrike
Yes, circlips.
Have tank off.
Started on left side injector, no problem, used scredriver to slightly pry up and pulled off. Injector o-rings looked good.
Went to right side injector and noticed no circlip. Bike bought used. Whoever worked on it before has a dent like a hammer strike at the top so the circlip groove is messed up. Yet it has never leaked.
How difficult is it to pull the injector on that side after taking the plate off? Do I need a special tool?
Old Apr 4, 2026 | 04:42 PM
evotrike's Avatar
evotrike
By the way, these were the original black rubber fuel lines. Exterior surface was looking iffy.
Old Apr 4, 2026 | 06:31 PM
evotrike's Avatar
evotrike
Do I need a fuel fitting or a fuel injector? Spec'd as 2 different parts in manual.
Are fuel fittings replaceable, or are they cast into throttle body?
Old Apr 4, 2026 | 08:03 PM
evotrike's Avatar
evotrike
OK, Got fuel fitting off.
Now "just" have to cut the circlip groove where it is dented.
IronAss
EVO
Jul 27, 2022 10:52 AM
nadajoey
Jan 18, 2022 06:31 PM
Alain
Oct 13, 2014 03:19 PM
deke
Carburetor Related
Sep 18, 2012 08:35 AM
kjelders
Jun 22, 2012 03:43 PM
