Softail seat interchangeability
Old May 8, 2026 | 03:00 PM
cwhite6's Avatar
cwhite6
Those two bolt tabs will bolt up to the holes that have plastic plugs in your picture. Pull the plastic plugs out of your frame. Also, take the rear bracket off of your current seat and transfer it to the new seat. It will all bolt right up. The bolt size for the two side bolts is 1/2-13 x 3/4". That bolt is shown in the parts manual as standard for a FXSTC and FLSTF. I have the same frame as you and my seat bolts on the same way.
Old May 8, 2026 | 03:25 PM
Mountain_man's Avatar
Mountain_man
Ok cool, yeah that’s what I was hoping.
Ill have to find some fine thread bolts, if it comes down to it, I’ll get some from an Indy
thanks for the info Mano 😁
Old May 8, 2026 | 04:17 PM
cwhite6's Avatar
cwhite6
You're welcome. You should be able to find 1/2-13 bolts at any hardware store. If you want to be fancy, most of the seat manufactures along with J&P Cycles and others sell those bolts. Here is a link to some OEM ones on eBay: OEM Seat Bolt
Old May 8, 2026 | 07:27 PM
Paintslinger16's Avatar
Paintslinger16
Active Streak: 120 Days
Yes that seat is actually broken, the rear tab it’s broken on the seat base, and I think from pictures the threaded insert is missing.
it will fit or attach with the side bolts but the rear will probably walk a bit, probably not that safe with a passenger.
If I rode solo and didn’t have a female moving on the back it would be ok,, the side bolts are really only for solo seat.
I wouldn’t pay much for that seat though
Old May 9, 2026 | 09:09 AM
Mountain_man
Yeah I was wondering why it didn’t have a rear mount, I’ll see what I can do when I get it, should be able to build something to secure the rear.
I won’t be carrying a passenger anyway so It’s not too big of a deal
Old May 11, 2026 | 05:08 PM
Corpus's Avatar
Corpus
That’s a shame about the broken off rear tab. I was going to say it looks like a nice seat, possibly a Mustang. I know when you buy a Mustang seat for a Heritage they will sell you a rear mounting tab but you can just take the tab off your existing seat. The way that one is broken I don’t know if you’ll be able to mount a new tab. I do think the side ones will fit but, as you say, if your passenger gets too jumpy it’ll probably move.
Old May 11, 2026 | 08:25 PM
cwhite6's Avatar
cwhite6
I am not convinced it is broken off. When the seat comes in, see if the inserts are still in the holes. If not, epoxy some threaded inserts in there and then either buy or make you a mount. It should be pretty easy to do.
Old May 12, 2026 | 11:20 AM
Mountain_man
Yeah I’m not really worried about the mount, I’ll fix it up when I get the seat, there’s always a fix 😁
Old May 12, 2026 | 11:21 AM
Mountain_man
this is an OEM “sundowner” Harley seat.
maybe Mustang made them for HD?
pjb
May 12, 2026 01:14 AM
byersmtrco
EVO
Sep 10, 2018 01:53 PM
kazzas fatboy
Apr 29, 2017 08:37 AM
FEAR 3 racing
May 6, 2013 01:44 PM
DeJavu
Custom Models
Jul 27, 2007 08:12 AM
