Tappet block screw-up?? Take a look.
Old Nov 16, 2007 | 08:33 PM
Clifton63's Avatar
Clifton63
Default Tappet block screw-up?? Take a look.
When I pulled my 1994 evo engine apart tonight I found the tappet blocks appeared to be cut where the tappet guide roller slots are. Only 1 tappet roller of the 4actually has a full groove on both sides (look at the picture). It has an Andrews EV27 cam. Why would anyone do this to the tappet block? do I need to replace them? Are these normal?
[IMG]local://upfiles/47442/77840951FD7D44328792FA755A64B405.jpg[/IMG]
Old Nov 17, 2007 | 06:33 AM
notlost_nc's Avatar
notlost_nc
Default RE: Tappet block screw-up?? Take a look.
What's the prior history of your motor? Looks like someone was worried about clearances and ground the blocks down some.
The EV-27 has none of these issues. I'd just get some new blocks. Was there a problem with your motor? Besides the oil leak?
Old Nov 17, 2007 | 07:21 AM
Clifton63's Avatar
Clifton63
The case was cracked at the cylinder stud mounting points. I am disassembling the motor for a replacement case.
Old Nov 19, 2007 | 09:26 PM
Clifton63's Avatar
Clifton63
Can anyone else confirm that these have been cut? The reason I asked is that I saw some aftermarket crome ones on the net and they look like they have been cut too. Do the actual stock ones look like mine in the pic?
If these have been cut I think I will go for the aftermarket chrome ones.
Old Nov 19, 2007 | 10:55 PM
riden2low's Avatar
riden2low
no thats normal....I have a set I pulled out of mine and they are the same
*kingpin*
EVO
13
Jan 21, 2015 09:19 AM
Nevsat13
Shovelhead
Jan 2, 2014 09:36 PM
zoood
Jan 2, 2012 05:30 PM
alaskajeff
Aug 31, 2010 08:09 PM
pococj
EVO
62
Dec 18, 2009 06:37 AM
