90 FLHTC Carb Coughing
Old Nov 17, 2007 | 09:23 AM
Team Flash's Avatar
Team Flash
Default 90 FLHTC Carb Coughing
I sure hope you experts can help me with this issue. I have a 90 FLHTC with a newer (10K miles) EVO engine, Mikuni carb and slip ons. The weather has cooled down here but not much as I live in AZ however my cold starting is giving me fits. I follow my usual process by pulling out the enrichner, give it a twist of the throttle and she fires right up. The problem is my idle is way low, it spits back through the carb and dies. This is very frustrating as I never had any issues with the idle or cold starts before. Any help you can give would be greatly appreciated.
Old Nov 17, 2007 | 05:58 PM
pan620's Avatar
pan620
3rd Gear
Default RE: 90 FLHTC Carb Coughing
Your slow jet ( intermediate jet) is to small and the cooler weather has made the problem worst, install a jet 1 or 2 sizes bigger will fix it.
Old Nov 18, 2007 | 10:53 AM
paco's Avatar
paco
Hey Flash,
On both my mikuni's there is an idle adjustment **** hanging down under the air cleaner. You can go up and down with the idle speed using this ****. It looks like a **** on thr end of a cable on my 2 carbs.
This might help.....
http://www.mikuni.com/fs-tuning_guide.html
later.............
Old Nov 18, 2007 | 02:52 PM
jbhoyle's Avatar
jbhoyle
Don't know if this works on a mukuni, but that is what will fix the problen on a CV. Went from a 45 to a 46 slojet . Runs and idles much better.
ORIGINAL: pan620
Old Nov 18, 2007 | 05:32 PM
JBaker421's Avatar
JBaker421
Big Kahuna HDF Member
ORIGINAL: paco
Hey Flash,
later.............
Ditto for my mikuni on my '86. Have to crank that idle up a little at first and then let it back down when it warms. That's in addition to the enrichener for a couple of minutes.
Is that why mikunis are so expensive - production costs on that do-it-yourself dongle?
Old Nov 19, 2007 | 02:11 PM
Team Flash's Avatar
Team Flash
Hey Guys, I had been playing with the idle but didn't think it was the long term solution. I will mess with it and check my jets too. This spitting through the carb was driving me crazing riding to work this morning as it continued even after the engine was warmed up. I also found a link to Mikuni with some topics on my issue. Thanks
Old Nov 19, 2007 | 02:13 PM
Team Flash's Avatar
Team Flash
Paco, the link I found was the same one you included in your reply. Thanks
Old Nov 20, 2007 | 11:44 AM
fxstcguy98's Avatar
fxstcguy98
I would check for intake leaks before changing jets and settings on the carb.
Old Nov 20, 2007 | 02:19 PM
Team Flash's Avatar
Team Flash
UPDATE: I adjusted the idle as recommended and guess what... zero spitting back through the carb. It is a slight pain in the butt to adjust the idle at a stoplight but it is worth it. I am going to pickup some carb cleaner to check for intake leaks because I think that is a good thing to do anyway. Thanks to all!
Old Nov 20, 2007 | 02:46 PM
Redd's Avatar
Redd
Get 1 of those propane torches to check ur intakes. A lot cleaner than spraying carb cleaner all over.
lowflyer
Carburetor Related
Aug 18, 2014 08:20 PM
cajun1957a
Shovelhead
Feb 11, 2014 09:23 PM
som69
EVO
May 30, 2013 07:47 AM
Francois.j
Nov 28, 2012 12:16 AM
Robsteeler66
Aug 25, 2009 07:49 AM
