kit upgrades
Old Jan 10, 2008 | 06:36 PM
twobanger's Avatar
twobanger
Default kit upgrades
Has anybody out there tried the Edlebrock head/cam kit combo.
I have a 97 RK that needs waking up. Is something like this worth looking into?
Old Jan 11, 2008 | 10:22 PM
big mahk's Avatar
big mahk
Default RE: kit upgrades
I don't know about the Edelbock but you can't go wrong the Branch Flowmetrics set up. Jerry Branch did most of the head work and engine developement on the Factory racing Harleys in the '70's and '80's. It's basically Branch flowed heads, Andrews cam, Hi comp pistons,aftermarket ignition, Mikuni carb and all are set up to work together as a system. You can spend a lot of time and money trying to pick out for yourself which "this" will work with "that" and still end up with a foul running mess. If you don't want to go with the whole package , which IS a bit pricey, you can call them up and get the best route to take.
Of course if you had a local engine wizard you could probably reach the same place also.
Old Jan 18, 2008 | 08:19 AM
phat96's Avatar
phat96
Yesterday, I got back my 1996 Road King, w/ EFI, and I had the Andrew's #27 cam, S&S quick install push rods and the JMS lifters done. I'm also running a DFO for fuel management. Had it installed then Dynoed and came out with 68.3 horse and 81 torque. I think I woke her up a bit for less than 1000.00
Old Jan 23, 2008 | 05:33 AM
94Dan69's Avatar
94Dan69
Big Mahk, gives you good advice I might add that Doug @Headquarters is very good at head work and engine pakages.
www.head-quarters.com You may want to check out their site and give him a call.
Old Jan 23, 2008 | 07:10 AM
pjb's Avatar
pjb
haven't tried it yet. but you might consider Zippers 80/80 kit.
marvo75
Mar 23, 2014 05:31 PM
SGT89EVO
EVO
11
Nov 21, 2011 05:30 PM
Edster 69
EVO
28
Mar 3, 2011 03:56 PM
dwyleecoyote
Exhaust System Topics
47
Jan 4, 2011 03:00 PM
AFHuey
34
Jun 26, 2010 10:09 PM
