Seafoam
Old Feb 26, 2008 | 10:56 AM
Tucker99's Avatar
Tucker99
Default Seafoam
Ok, they're fixing the search feature, so lighten up.
Took the pipes off last night and noticed an appreciable amount of carbon on the piston and in the pipes. I have a big sucker air cleaner and any oil from venting gets sucked into the carb and this may explain the carbon.
I've usedSeafoam for years sucking it in through vacuum lines, and spraying it in the carbs of 2-stroke engines. I've never used it on the HD becauseof the high compression. Has anybody sprayed Seaform directly in the carb to remove engine carbon without screwing anything up?
Old Feb 26, 2008 | 11:17 AM
xxxflhrci's Avatar
xxxflhrci
Default RE: Seafoam
Save your money on Seafoam. If you want to clean up your top end, you can use a spray bottle to spray water in the intake with the engine running on a fast idle. The water will turn to steam and clean the piston tops, heads, and valves. Hot rodders have been doing this trick for decades.
Old Feb 26, 2008 | 11:35 AM
Tucker99's Avatar
Tucker99
Default RE: Seafoam
Ok, have you personnaly done this?? Did you do it until stall? Was the bike hard to restart?
Old Feb 26, 2008 | 11:40 AM
xxxflhrci's Avatar
xxxflhrci
Default RE: Seafoam
ORIGINAL: Tucker99
Yes, I have done it...many times. No, you do not do it until a stall. The idea is for the water to get sucked in and turn to steam. You only mist or trickle the water in, not pour a big stream. The bike won't be hard to restart, because you won't kill the motor.
Read the third paragraph down:
http://www.hotrodder.com/kwkride/tech.html
Old Feb 26, 2008 | 12:42 PM
Pilotguy1050's Avatar
Pilotguy1050
Default RE: Seafoam
hey, xxx,
Great little article link...! Thanks. I learned a couple of things.
Old Mar 6, 2008 | 07:11 PM
skullhead's Avatar
skullhead
Default RE: Seafoam
ORIGINAL: Pilotguy1050
hey, xxx,
Interesting I have never heard that before. I'll have to give it a try.
Huggerbugger
Feb 7, 2017 04:25 PM
wiguy
Engine Mechanical Topics
May 3, 2015 01:55 PM
paulhog
Mar 9, 2010 02:23 PM
J2X
Sep 1, 2008 09:26 AM
mchaous
Oct 31, 2005 06:16 PM
