HD EVO engine rebuild program
Old Mar 18, 2008 | 12:24 PM
Skullman's Avatar
Skullman
Default RE: HD EVO engine rebuild program
I had a 97 Dyna Convertible that when I sold ot had 135,000 miles on it. The only thing I did was change the lifters once at 60,000 miles. Took the heads off at 100,000 thinkin it'll be due for a rebuild but the lower end and valveswere still with-in specs. But I made sure I changed the oil at every 2000 miles on the dot. Getting work done also from a HD factory tech is well worth it if you are in god with ther dealer.
Old Mar 18, 2008 | 09:18 PM
blueglide88's Avatar
blueglide88
ORIGINAL: jokenroll
ORIGINAL: blueglide88
I had my motor done at around 147,000 miles. In my opinion, it was money very well spent. You get a factory produced engine. Despite what your local wrench says, he is NOT going to machine anything as good as HD can at the factory. You also get a 1 yr warranty.
With all due respect, I disagree. How do we know that "he is NOT going to machine anything as good as HD"?
The factory works with numbers, shops work with people. They want you to come back. Besides, is there special patented secret equipment only HD can use to machine cases? If "a factory produced engine" was better than anything else, why would so many people change so much inside of it? Don't we know that Wiseco pistons are better than the stock ones (that's what you get in the VTwinMfg kit)? Isn't it obvious that S&S reed breather is better than the stock rotating one?
Warranty is definitely a plus, but is it really worth it just for a year? So what, I used to have a car with a 5yr warranty, and it spent more time in the shop than on the streets. I got rid of that crap.
Isn't a major part of the fun making your own and truly unique bike? Mostly yourself?
IMHO, If you just want everything factory, and rely on everything factory, you'll be better off with Jap bikes. Factory wise, they're way more reliable.
BTW, that was one of the main reasons why I switched to HD - the opportunity to have YOUR OWN bike, made by yourself! You are making your bike for yourself, someone else is making your bike for money, I guess there is the difference.
Most local shops have a Bridgeport as their milling/boring machine. Now you can do some nice work on a Bridgeport, I've spent 15 yrs working on them, but you'll NEVER hold tolerances as close as the CNC machines that HD has at the factory. There is actually a great deal of know how and science behind the tooling that manufacturers use to assureproper tolerances. Tool wear and replacement, proper fixturing, speeds and feeds, etc. Ask you local wrench about his inspection methods, and he'll wonder what language your talking. Have you taken the factory tour? It's pretty impressive. Now if your local wrench has the money (big bucks) and has purchased the latest in CNC technology, he'll do a good job. But he will not repeatedly produce the same tolerances that a factory will. He does not have the quality control to do it.
The ability to put in aftermarket parts can be a plus if you know which components work and which ones don't and what combination to use. But in the long run, deviating far from stock will shorten your engine life. How many abig bore/big cam engines do you know that have 147,000 miles on them? I don't know of any. More power to you if you want to go that route, but I know I spent my money well.
Old Mar 18, 2008 | 10:15 PM
blueglide88
ORIGINAL: jokenroll
Most local shops have a Bridgeport as their milling/boring machine. Now you can do some nice work on a Bridgeport, I've spent 15 yrs working on them, but you'll NEVER hold tolerances as close as the CNC machines that HD has at the factory. There is actually a great deal of know how and science behind the tooling that manufacturers use to assureproper tolerances. Tool wear and replacement, proper fixturing, speeds and feeds, positive or negative rake cutters, etc. allplay a partin the final product. Ask you local wrench about hisCMM machine, and he'll wonder what language your talking. Have you taken the factory tour? It's pretty impressive. Now if your local wrench has the money (big bucks) and has purchased the latest in CNC technology, he'll do a good job. But he will not repeatedly produce the same tolerances that a factory will. He does not have the quality control to do it.
Old Mar 19, 2008 | 08:46 AM
jokenroll's Avatar
jokenroll
The truth might be somewhere in the middle, as it’s often the case. We definitely need to know what are we bolting on, and what works better (or not). Moderation should be exercised in the performance boosting, if we want reliable and long-lasting motor. But, let’s not forget the fact that beside quality and reliability, the factory objective is always cost effectiveness and trying to bring the consumer price down, which will result in at least compromising quality of materials. I still do not see anyone would argue that Wiseco, for example, is worse than the stock. If all HD parts were the top quality, the bike would cost at least 70K, like crazy choppers do. Concerning more precise equipment, it is definitely good, but is it that necessary? People have trusted their shops for decades (centuries already?) for re-boring cylinders. Does case boring require more precision? And with many kits, you get already factory-matched pistons and cylinders – I do not think the quality would be inferior to HD. As of the cc – it is probably insane to make 102†out of stock Evo (besides the cases would not take that), but 88 or 93 is not that big. Factory TCs are 96 now. I believe if you do a proper thermal and road break-ins, if you have an oil cooler, if you use the top quality oils (which are not HD oils BTW, as far as we can read here and in many other places), your “custom†engine will not live shorter than the factory one. Well, I guess, time will tell – I got a brand new speedometer with 0 on it [8D]
Old Mar 19, 2008 | 01:14 PM
JBaker421's Avatar
JBaker421
Big Kahuna HDF Member
You shouldn't, imho, bore a cylinder all the way out with any of those machines. They don't leave the proper texture for ring seating and piston/ring lubrication. You need to hone the cylinders.
The hone will get the cylinder round and straight, and give the proper "grit" to it every time. I'm talking about a proper rigid hone and not of course a deglazing hone.
I used to own an automotive machine shop and we could get the cylinder round and straight enough that you couldn't read variations with a dial bore micrometer. We also got the proper finish grit.
We bored cylinders a touch small and honed them to exact fit and cross-hatch. We also removed all tool marks from boring and left the proper surface for the rings and pistons to seat, break in and lubricate.
I think it matters most how much the machine operator cares about the quality of work. You could actually bore the cylinder all the way with just a Van Normon or Sunnen rigid hone, usingincreasingly finer grit and get a perfect job. You just gotta know how to read a mic and have the training and practice.
MilsurpShooter
Oct 29, 2018 07:20 AM
davepapa
Jul 14, 2012 02:48 PM
mrsmartass2003
Custom Models
Jul 4, 2012 07:58 AM
MNHarley
Dec 2, 2009 08:16 PM
harleydude68
Apr 13, 2008 03:27 PM
