big bore evo question
Old Jun 4, 2008 | 12:50 AM
chopperhead2's Avatar
chopperhead2
Default big bore evo question
First let me say that while I am a HD mechanic, most of my engine expereince has been with twin cams but I`ve done a few 80" top ends and cam swaps. Ok, soI got this 96" evo project in my garage. It was suppost to be a simple install the top end and cam and get the motor ready to go in the frame. Well this is my first big bore evo andI didn`t realize some of the special clearances needed. These are S&S 3 5/8" sidewider cylinders on stock cases. I`m all set to put the barrels and pistons on and I notice the hole in the base gasket for the oil drain doesn`t line up. soI dig out the instructions that came with the kit and it says to chamfer the oil hole on the side that doesn`t line up. so whats the best way to do this without getting metal shavings in the crank cases? I need to get this thing together for the guy not to mention it`s become such a pain in the *** that I want it gone but I won`t half *** it just to get it out of here. i need to get it done right so it doesn`t come back to bite me later. Thanks guys.
Old Jun 4, 2008 | 05:08 AM
dog155's Avatar
dog155
Default RE: big bore evo question
You have a conundrum.There are all kinds of ways to do it BUT no guarantees you will keep all the crap out.Maybe a plug of somekind bathed in grease that you will be able to pull out when done.You know the best way to do it.Good Luck.
Old Jun 4, 2008 | 09:16 AM
chopperhead2
Yeah I just didn`t want to split the cases again. I already had to do it when we fixed the cylinder stud threads.
Old Jun 4, 2008 | 10:04 AM
megawatt's Avatar
megawatt
Maybe tip the engine so you are work "uphill" with a vacuum cleaner sucking next to where you are chamfering.
Old Jun 4, 2008 | 02:18 PM
chopperhead2
ORIGINAL: megawatt
That is pretty much whatI planned to do after talking to a couple people at work. I think this would be the best way and i won`t have to split the cases. thanks
Old Jun 4, 2008 | 07:15 PM
Rob85WG's Avatar
Rob85WG
Can you chamfer the jugs instead of the cases?
Old Jun 4, 2008 | 07:55 PM
chopperhead2
They are S&amp\\;S barrels for big bore and they are the reason I have to chamfer the cases. I`m going to go slow and just take enough matieral to line them up.
Dillinger13
Engine Mechanical Topics
Feb 14, 2021 02:42 PM
Gnassty
Feb 20, 2019 10:21 PM
motohead20
EVO
Apr 15, 2013 12:21 AM
McCormack090305
Exhaust System Topics
May 14, 2011 08:59 PM
bluezguy
Shovelhead
Aug 14, 2006 10:22 AM
