Back into the starter.... Again!
Old Jul 3, 2008 | 10:40 PM
96 Wide Glide's Avatar
96 Wide Glide
Default Back into the starter.... Again!
2nd time in about 1000 mi.
First time was the last ride of the season last year. Warm motor, kicked back when starting, starter clutch pooched!
Yesterday, warm motor, kicked back on starting, stripped two teeth off the pinion gear [:@]! Guess since the clutch is near new, the next weakest link is the pinion gear.
I think the jetting is about right, idles good, starts up good with enrichner, runs great.
With a warm motor I just turn the throttle a bit and hit the starter. Usually starts in one revolution or less. Any ideas whats causing these occasional kick backs? This is getting expensive!
&nbsp\\;
Cheers... Ben.
Old Jul 4, 2008 | 07:34 AM
dog155's Avatar
dog155
Default RE: Back into the starter.... Again!
Starter kick backs are usually caused by too much ignition advance.Someone has a devise the disables the ignition for the first couple revolutions,to let the motor get rolling.Good Luck&nbsp\\;
Old Jul 4, 2008 | 08:39 AM
Tuggin's Avatar
Tuggin
I would check the timing.
&nbsp\\;
Tom
Old Jul 4, 2008 | 09:18 AM
Ribcracker's Avatar
Ribcracker
yep thats why all the good after market ignition systems have a kick/electric setting so if when you start em on the button gives the engine time to spin up before firing.
foxtrapper
Mar 27, 2013 04:05 PM
liljon140
Apr 6, 2012 06:24 PM
FXRjockey
Electrical/Lighting/Alarm
Aug 30, 2009 07:40 PM
WRAITH
Nov 12, 2008 10:17 PM
tim50
Jul 4, 2007 05:28 PM
