Starter runon problem
Old Jul 22, 2008 | 08:52 PM
rablum13's Avatar
rablum13
5th Gear
Default RE: Starter runon problem
The solenoid was the problem with the runon. As far as the slow cranking the dealer gave the usual answer, "old bike, old wiring, we will look at it if you want." Which was unusual because they usually won't work on the old bikes.&nbsp\\; (ie. 10 years +)
Old Aug 6, 2008 | 08:17 PM
rablum13's Avatar
rablum13
5th Gear
Thumbs up fixed
The solenoid was the run-on problem. I remedied the slow cranking problem by taking off the relay ground and cleaning the frame and connector. I did this just to cover all the bases and that wire had never been off in 20 years.
Old Aug 6, 2008 | 11:54 PM
megawatt's Avatar
megawatt
rablum13, Glad you got it fixed.
I think I will have my bike running tomorrow when the new, replacement battery gets here. I gotta post the details of this stinking ordeal once I have it all back together and know it is really fixed.
Old Aug 17, 2008 | 09:42 AM
Gigawitz's Avatar
Gigawitz
Slow cranking is most likely worn contacts inside the starter, They are cheap and easy to replace.
Red 62
General Topics/Tech Tips
Mar 28, 2014 02:29 PM
kevinviz
Mar 6, 2013 11:57 AM
intruder400ex
Nov 8, 2012 05:40 PM
Robert Evans
Mar 27, 2012 10:43 AM
boneman171
Nov 27, 2009 11:49 PM
