Front end should be off the ground so no weight is on the tire. Also need a good measuring cup that measures off single ounces. I've found it works best if you have an impact screw driver to do initial loosing of drain screw. good luck
Man, you need to relax, it's as easy as changing the engine oil . The springs aren't going anyware. Next thing on your list after this, is to get a service manual.
Its real easy like outhers have said.. Raise front wheel off the ground remove the top tube nuts (Springs will not come out) remove lower drain screws.. Let drain... put drain screws back in fill with fluid (A good funnel sure helps... put top nuts back on
It's simple as stated above. Under the top bolt there is another that holds everything in the fork tube you'll find a small hole in it to refill the fork tube. I found a measuring funnel at advanced auto that works great.
