true dual help
Old Sep 18, 2008 | 07:53 PM
perpulreaper's Avatar
perpulreaper
Default true dual help
can anyone tell me why a set of true duals made for a flh from 85 to 06 wont fit an 84 with a evo motor
fond these and called them and they dont know any more than i do
http://cgi.ebay.com/ebaymotors/ws/eB...m=370085001719
all there tek could say was my old muffler wont work B'F'D i'm running strait pipes w/fishtails not stock
Old Sep 18, 2008 | 08:38 PM
wjl24's Avatar
wjl24
I'm pretty sure the only difference is that on the 94 and down they used a muffler with a flange that bolted up, 95 and up used a slip on muffler with a torca clamp.
Old Sep 18, 2008 | 09:15 PM
perpulreaper
so this will bolt to my motor and hangers
Old Sep 19, 2008 | 05:01 AM
grbrown's Avatar
grbrown
I have late model (1994+) Samson true duals on my 1990 Glide, with late model mufflers. As plj says, earlier exhausts had a different pipe to muffler join, so you cannot mix early with late. If you use all post-1994 stuff, like me, you should be OK. I only fitted my Samsons with S&S oval mufflers earlier this year.
Old Sep 19, 2008 | 08:03 PM
perpulreaper
my bike has a pipe that you slip the muffler on then clamp it tight
i have strait pipes with fishtails on the stock header pipes now
what i want to do is replace the header pipe with the two head pipes that come with the set i gave the link too , the ones on ebay say they will work on a 85 to a 2006 , i have a 84 FLHTC with a evo motor so i guess that means i have a late 84 because i have sean 84's with shovels
the pipes i have found for my year say they work on 79 to 84 which makes me think they are foe shovels
what i was hoping was someone here may know if these pipes will work on mine or will i need to make something to get them to bolt to my bike where my stock pipes hang or will my trany get in the way of the back pipe
sorry post is so long
HOGNIT
Jul 2, 2015 10:34 PM
Tactical111
EVO
16
Sep 3, 2010 02:05 PM
wrenchguy24
Nov 2, 2008 01:42 AM
LTDDD
Exhaust System Topics
Nov 2, 2007 07:36 AM
HilllBillly
Jun 19, 2007 01:28 PM
