wheel fitment question
Old Sep 19, 2008 | 10:29 AM
harley7316's Avatar
harley7316
Default wheel fitment question
Hi was wondering on a stock 92 fatboy with inch and half belt and stock tires would a 18x3.5 rear and 18x3.5 on the front fit with out modifiying anything?stock is i think 16x3 stock tire wouldnt fit?thx
Old Sep 19, 2008 | 06:56 PM
t150vej's Avatar
t150vej
You can get into ALL SORTS of problems with axle spacing. Not saying you can't do it, honestly I don't know, but be careful. Even if you have the correct clearance for everything to work, handling may go bad. be careful and good luck.
Old Sep 20, 2008 | 05:21 PM
Classic Beast's Avatar
Classic Beast
about the max size of tire you can fit without rubbing the belt on the 3" rim is a 140 the fender will almost fit a 180 but then you have to space over the tranny with an off set plate and a spacer on the engine plus the pulley will have to spaced over which will hit the swing arm. there are a few wide tire kits around that come complete, Heartland has some good ones. Take your time and measure things carefully. If the 18" wheel your talking about is a newer style it could be set up for a 1" axle and the disk/ rear sprocket holes are a larger size. It can be a night mare with the spacers they are really hard and not something you want to cut with a hacksaw. Best thing is to buy a few 2" custom ones and cut them down as you don't want to end up with a bunch of smaller spacers. Good luck and let us know how you make out
pulser9
Oct 28, 2015 09:39 PM
GolfWrench
Nov 13, 2014 04:51 AM
homiegfunk53
Aug 23, 2013 04:27 PM
smokeyrider05
Wheels/Tires
Mar 6, 2013 04:01 PM
steinbc
EVO
Jan 21, 2009 03:33 PM
