Another swingarm question
Old Jan 17, 2009 | 10:04 AM
steinbc's Avatar
steinbc
Stage IV
Default Another swingarm question
Last fall started with wanting to get my 99 fatboy repainted this winter. Well, you all know harley projects tend to spin violently out of control. My repainting project turned into new fenders, stretched tank, thunderheader pipe, ness big sucker, and forward controls. In addition a woods w-6, drag bars, new seat, and possibly a crane ignition will be on before spring. Now I am thinking about doing a wider tire kit on it. I don't want to go too big due to the potential trans issues and the effects on handling. I have been reading the forums and found that you can fit a larger tire in the stock swingarm. How big will fit easily (rim size/wheel size)? I was thinking 160 - 180 possibly 200 MAX (i read that a 200 would be tight in another forum). I know that the spacers are going to have to be modified but do you need to go to a narrower pulley? What about the front pulley?
Old Jan 17, 2009 | 02:15 PM
miacycles's Avatar
miacycles
You have to "reverse engineer" this. First measure inside the narrowest part of the rear fender, if there is a wire loom on one side you need to subtract a like amount from the other side in order to keep the tire centered. Once you've determined the maximum width you can put under the bike then you select the wheel. Next you figure what you need for axle spacer to put the wheel centered, then you will need a narrower rear pulley or chain. Once you've figured that out you will need to figure what spacers you may or may not need for the pulley/sprocket and brake rotor. Unless you go too wide the front pulley should work with most narrow belt conversions. Hope this helps
Old Jan 18, 2009 | 04:46 PM
grbrown's Avatar
grbrown
Cool
Yup - been there! Sympathies from across the Atlantic, and best of luck with the present project. If your weather is anything like ours, there is plenty of time yet until the riding season gets here....
Old Jan 21, 2009 | 02:04 PM
kickstart pan's Avatar
kickstart pan
you should be able to go to 150 and a chain with out any trouble.
You can prob go to a 150 even with a 1" pulley
Stay with the stock rim and it makes the tire tread look wider from the back anyway
More than that and see all of the above, it gets exspensive and when your done you wonder why you wasted all that for a wide tire.
Old Jan 21, 2009 | 03:33 PM
extech's Avatar
extech
I have to agree, I've seen so many guys spend a bunch of cash putting on a wider tire that will be mostly covered up by the fender. The only wide tire conversion I'd recommend doing is the p/m kit, they are pricey but really look and will totally change the look of you bike. I think the whole wide tire craze is coming to an end.
Bbbadboy
Mar 16, 2015 05:09 AM
GolfWrench
Nov 13, 2014 04:51 AM
GolfWrench
Nov 12, 2014 09:34 PM
snip0721
Mar 20, 2009 12:09 AM
harley7316
EVO
Sep 20, 2008 05:21 PM
