Handlebar Squeak
Old Sep 21, 2008 | 06:46 AM
FreedomRider's Avatar
FreedomRider
Cool Handlebar Squeak
I have a '96 FLHTCI that I have looged 112,000 mile on and have recently noticed a squeak which sounds like is in the handlebars. I don't hear it all the time, it comes and goes, speed or road condition doesn't seem to matter. It is that annoying eek, eek, eek, eek, sound. I find if I apply a little pressure on the left bar the sound stops. The direction of pressure doesn't matter, up, down, pull, or push. I have checked all the mounting under the fairing and the risers, everything is tight. I don't find the clutch cable rubbing anywhere either. I have also checked the air hoses coming off the handlebar since this handlebar is an air resivoir for the front forks. I have checked the left grip and switch housing with no luck. The bushings in the top triple tree are original. Any ideas or suggestions where to look next ?
Old Sep 21, 2008 | 07:46 AM
oldroadie's Avatar
oldroadie
I've had that on a different bike and it was the fork shroud, a little shot of silicon lube up the shroud fixed it right up.
Old Sep 21, 2008 | 08:31 AM
hogdoctor's Avatar
hogdoctor
Put a little bit of silicone grease around the speedometer cable jacket where it goes through it's anchor on the front fender.. that's a really common squeaker.
Hogdoctor
Old Sep 21, 2008 | 04:22 PM
FreedomRider
Thanks for the suggestions ... I'll lube the areas you mentioned and let you know what happens in a couple days. But I'm having trouble understanding how when I push on the left bar the squeak stops if it is the speedometer cable. I'll get back.
Old Sep 21, 2008 | 05:57 PM
sqdealgeorge's Avatar
sqdealgeorge
Maybe it's time to replace the handlebar riser rubber bushings Evos are amazing bikes Time will tell for the twin camers
Old Sep 22, 2008 | 05:04 PM
HD7585's Avatar
HD7585
Have the neck bearings been repacked with grease in those 112 thousand miles......If not,there due
Old Sep 23, 2008 | 07:52 AM
bikerdude1903's Avatar
bikerdude1903
Yes, the neck bearings have been taken care of more than once in the 112K miles. Thank you for the suggestion.
Old Sep 24, 2008 | 06:49 AM
hogdoctor's Avatar
hogdoctor
Pull your outer fairing shell off and check the fairing support brackets... fairly common
to see them cracked, esp up at the top, the cracked metal rubs and squeaks.
Hogdoctor
Old Sep 24, 2008 | 10:36 AM
bikerdude1903
I have pulled the outer fairing, checked the speaker mounting, oiled the speedometer cable inside, checked the clutch cable routing, checked the tightness of all the gauge mountings, checked the hoses from the handlebar air resivoir, and replaced the left support bracket 3 months ago cause it was cracked. I last had the fairing off 4 days ago to recheck everything again, the support bracket was OK.
adiddik
General Topics/Tech Tips
Apr 13, 2019 09:02 AM
128auto
Aug 3, 2018 09:48 AM
zdrifter
Feb 27, 2014 09:35 AM
bikerdude1903
EVO
Apr 27, 2009 02:59 PM
07street
May 7, 2007 04:09 AM
