stage 1
Old Oct 8, 2008 | 09:39 PM
0o0ow's Avatar
0o0ow
Default stage 1
ok i searched this here.. just want some real reviews on what you think...big sucker kit=good bad?SC ignition=good bad? light cam for torque andrews=? can a shade tree mechanic like myself do all the work?/
98 ftstf cv carb
jetted
pipes
thanks dave
Old Oct 9, 2008 | 01:03 AM
fogcity123's Avatar
fogcity123
I can respond to the big sucker kit. I put one on my sportster and it fit good, was easy to install, and good quality. I put the big sucker cover on and didn't like it - ordered a disk cut out of aluminum or steel from Ebay which just covers the front (outside) of filter and it looks better, I think. I also just put a s&s air cleaner on my softail and I like that one worlds better - went on in 30 minutes (but I do have a ss shorty carb).
Old Oct 9, 2008 | 01:25 AM
hotrod351's Avatar
hotrod351
andrews ev27 cam and ofcourse youll need adjustable pushrods. can you install the cam, i dont know. a good shop shouldnt charge you that much. what they do is cut the old pushrods, that way they dont have to remove the rocker boxes, and then install adjustable ones. thats what i have, along with a little head milling to get the compression up a bit. i can go up hill in 5th with ma and the old lady at 50 without lugging and the total ofo our weight is around 450lbs.
Old Oct 9, 2008 | 04:52 AM
HGM's Avatar
HGM
As to if you can do it, only you can answer that one..
I've found a ton of good info here. Do a little surfing and you should be able to pick the components and decide if your comfortable with it.
Old Oct 9, 2008 | 04:32 PM
0o0ow's Avatar
0o0ow
Default thanks folks
aloha thanks folks u are the best...
andrews cam,torrengton bearing,breather kit..somethin to up the electrics should do for now
its wrenchin time
thanks dave
Old Oct 10, 2008 | 03:35 PM
hardluk1's Avatar
hardluk1
Look at JIREH for assesories, maybe atleast your ignition . They don't have a big choise to pick from but great prices on what they have and there ignition seems to be a good one. The ev 27 is a good cam choise and if you just replace your rockerbox gaskets you can reuse the stock pushrods.
Old Oct 11, 2008 | 03:10 PM
0o0ow's Avatar
0o0ow
Default service manual
i have the harley service manual and i'm a pretty good wrench..but the manual is really lacking in cam replacement and pushrod lifter adjustment...anyone have a detailed steps in cam replacement with settings and hopefully pics..98 flstf
thanks an ALOHA
DAVE
Old Oct 11, 2008 | 07:34 PM
hardluk1's Avatar
hardluk1
Disregard
Old Oct 12, 2008 | 07:56 AM
HGM's Avatar
HGM
Check that link, there's just about anything you need on there..
Here is another quick link to it.
Good luck, have fun!
briharley
Jan 18, 2020 06:54 AM
ken98k
EVO
14
Jul 30, 2019 07:44 PM
Taylor Wright
Dec 2, 2018 07:42 AM
Blown 331
EVO
Dec 9, 2007 08:08 AM
Blown 331
EVO
15
Feb 23, 2007 08:53 AM
