Ultima engines your results
zoood
We have sent a request for full set of bearings, gasket kit and oversized pistons and rings. We shall see how well they back their product.
I sure expected more than 1500 miles out of a new motor! Anyone else had this type of problem out of an Ultima engine?
https://www.hdforums.com/forum/evo-c...is-report.html
The high aluminum in ours was from the rocker supports and also tore up the bushings in the rockers , that was pretty easy and not to expensive to fix, I was very careful to make sure the new rockers fit and were smooth etc. We also had two different Ultima lifters go bad, the front cylinder was first then a thousand or so miles later a second lifter went out in the rear cylinder, which also wore heavy on the cam so I replaced that as well.
Right now it has maybe 17,000? miles and seems better, but the iron levels are still higher than normal. I was not too lucky getting help from Ulitma, and I did not push the issue because I waited too long after the tapping noise started, but the total costs for repairs so far were not much more than $500.00.
The biggest problem owning an Ultima engine for me was finding a good Indy shop to work on it - one that I could trust, located near me. I may have found one in Harrisburg Pa but I haven't contacted him yet as now things seem to be pretty good. I am still happy with it all, even with the $500 costs over 2 years and 17,000 miles doesn't seem unreasonable to me. I am more upset that we were unable to ride much this year because of personal problems.
RJ
RJ
