4 spark plugs 1984 FLTHC
Supposed to:
remove both plugs (in your case, one from each head - remove wire from the others)
lock throttle in wide open position
turn it over at least 5 compression strokes
all this preferably with the engine warm
120 is acceptable, but a reasonably fresh engine (stock) will pump up 140 - 155 if done as above. Surely they freshened it up, even if the only thing done was remove/modify the heads. At the same time, if it runs well, doesn't smoke or use a lot of oil - just ride and enjoy it
Just an after thought - don't think you could put dual plugs like that in an Evo head that wasn't cut out. (domed) Possible they put domed / twin plug heads over flat top (stock) pistons?? Possible I reckon, and if that be the case, 120 compression is jammin!
I'm not that up on the "trick stuff" some of these guys do, so I'm totally open to being corrected on the last paragraph...
The 4 plug deal, I would think someone has added 'domed pistons' & perhaps a hot cam..
Ride that baby....
