older bike New model pipes
Old Mar 10, 2009 | 01:59 PM
mp's Avatar
mp
Jirehcycles.com has lots of heat shields with a $70 one being the most expensive I see. Hard to tell what fits what, though.
Old Mar 11, 2009 | 09:10 AM
rivercityslim's Avatar
rivercityslim
Originally Posted by t150vej
Looked at the Fulsac on your recommendation a year or so ago and really liked it.
I don't think I ever posted a pic after installing the Fulsac. A much cleaner look, and it sounds great. Here's the bike last Spring (other minor changes since, the most noticeable being CB removal):
Old Mar 19, 2009 | 08:42 PM
93 Bagger's Avatar
93 Bagger
How should I go about cutting the flange off my pipe to fit a set of Samson mufflers from a 2004 Electraglide classic on it? Would my Milwaukee sawsall with a fine metal blade work good enough if I took my time? Anything I should do to make sure the cut is a clean one? Thanks!
Old Mar 20, 2009 | 01:25 PM
t150vej's Avatar
t150vej
That would work but.... I've seen muffler shops do it and the ends (on regular pipe) look like crap. Get a cheap tubing cutter large enough to do it. They look like a pipe cutter, just made cheaper... or borrow a pipe cutter.
Old Mar 20, 2009 | 01:56 PM
big cahuna's Avatar
big cahuna
I used a hack saw and just took my time. you need to cut it tight enough to slip the muffler over the pipe . my left side always seemed looser then the right side, and I had the muffler slip off twice before I put the dog bite on it.,,
Old Mar 23, 2009 | 10:42 PM
93 Bagger's Avatar
93 Bagger
A mechanic at work talked me into trying a ceramic sawzall blade. That didn't work so swell. I used the finest metal blade that I had and it worked perfect!
My left one bolted right up real easy too, but the right side was a bastard! Are these pipes the same size????? I have to say that these Samsons sound AWESOME!
lmz5150
EVO
May 25, 2017 01:40 PM
ronnyvous1
Jan 22, 2010 09:14 AM
dz1087
Jan 10, 2010 03:19 PM
dan boudreau
EVO
Jan 20, 2008 01:56 AM
EvoFatboy
Exhaust System Topics
Nov 28, 2007 10:12 AM
