Evo Top End Rebuild Questions....
Old Mar 26, 2011 | 10:19 PM
Spanners39's Avatar
Spanners39
That oil from the air cleaner is called reversion and usually appears when you change the pipes, drag pipes are the worst for causing reversion and its all about exhaust harmonics...no cure except standard pipes...or some radical breather mods.
Old Jul 26, 2017 | 08:00 AM
timay67's Avatar
timay67
Stage IV
Default Evo rattle
Originally Posted by t150vej
No, Evo valve rattle isn't normal. You can expect some valve train "noise" when upgrading a cam, but not a rattle unless you get really radical on the modifications. Mine rattled since 12,000 miles and it took me years and lots of wasted dollars to figure out the problem for taking advice from too many people. Have to get to work and be back Friday, but send me a PM and I'll clue you in.
Always a good idea to freshen-up the top end if you have time and an extra 75.00 ... while you're into it.
I know this post is from 2009, but I still have a rattle in my Evo after replacing lifters, push rods and rocker arms. What caused the rattle in your Evo?
Old Jul 26, 2017 | 08:24 AM
timsmcm's Avatar
timsmcm
the only thing left is either the rocker shafts are moving in the mounts or your pinion, to breather,to cam gear mesh is off. it can sound like a hammer hitting an anvil if loose. If too tight it can sound like a loud whine.
Old Jul 26, 2017 | 08:50 AM
HGM's Avatar
HGM
I'm a believer in these.. Chased a rattle for years, they made a difference..
http://rockerlockers.com/wordpress/
1/2crazedbikr
EVO
13
Mar 2, 2014 11:13 AM
lieutenant G
EVO
15
Dec 7, 2011 10:49 PM
blair
Sep 30, 2011 11:24 AM
PakMul
Engine Mechanical Topics
Sep 19, 2010 11:02 AM
Cool Hand Lance
EVO
Feb 22, 2008 07:36 PM
