I have a 97 Ultra
Recently I lost the brake lights, horn and turn signals at the same time.
Running lights are fine. Fuses are good and have power.
If I jump the rear brake switch, I can hear the relay work and the brake light comes on.
It seems like there is a common power wire problem.
Anyone have a copy of the wire diagram?
Two months ago I added an extreme HID light which is working fine.
Don't have the diagram for a 97, but I would try disconnecting the HID first, and see if that gives any relief. Next I would check all harness connectors. I have heard of moisture getting in them and corroding the connections over time. Good Luck.
