Carburator and Pipes????
Old Oct 4, 2009 | 10:11 PM
Dave Ferguson's Avatar
Dave Ferguson
1st Gear
Default Carburator and Pipes????
Greetings to all,
Im looking for some guidance and advise, I run a 98 Dyna Wide Glide and want to put on an S/S Super E Carb and a set of Vance and Hines Longshots is this a good combo for my bike or will I end up regretting this?? Thoughs comments and opinions??
ONWARD
Ferg
Old Oct 5, 2009 | 08:00 AM
miacycles's Avatar
miacycles
If you are not doing any internal mods the stock CV with a few inexpensive mods is more than enough carb. It will give you better low end and mileage than the S&S too.
Old Oct 5, 2009 | 02:30 PM
Hackd's Avatar
Hackd
X2....
Old Oct 7, 2009 | 08:14 AM
I8SMK4U's Avatar
I8SMK4U
Thats what I hear. The stock carb is more carb than people think. If your just going to add pipes and maybe a cam the stocker is perfect. All my buddies that added head and pistons all run Mikuni's.
Old Oct 7, 2009 | 09:35 AM
98 FLHX's Avatar
98 FLHX
It's my understanding that the CV is a better than average carb.
Adding a tuners kit puts it where it needs to be. I run one, and it's
provided quite good performance with just a DynoJet kit.
Once you get up to around 100 cubic inches, it just can't move enough
air, so an upgrade would be in the cards.
Nothing wrong with the old CV......
Old Nov 27, 2009 | 11:19 PM
NorthGeorgiaHawg's Avatar
NorthGeorgiaHawg
My CV runs great! I put a kit in it with bigger idle and main jet, and better needle, and drilled out the vacuum hole in the slide to 1/8". I run a Hypercharger Pro (K&N filter) and V&H Dresser Dual headers with either V&H Big Ovals for long trips or straight-through fishtails. I thought about putting on an S&S E, but I have also read about the CVs ability to auto-adjust for altitude, which comes in handy on mountain trips. From what I've read, slide carbs like the S&S can't auto-adjust for altitude.
Old Nov 29, 2009 | 08:25 AM
hotrod351's Avatar
hotrod351
that what i have on my 90 fxstc, sounds great, baffles removed. the only problem is when i come out of a driveway and lean to the right i can kiss my pies on the ground and im sitting at stock height.Carburator and Pipes????-dscf0589.jpg
Sudsy
Jun 22, 2012 10:06 AM
8super2glide
Shovelhead
Aug 30, 2010 03:09 PM
Paul G
Exhaust System Topics
Aug 23, 2010 09:53 AM
tspierce
EVO
Mar 10, 2010 10:12 PM
sixshooter
Sep 12, 2009 07:15 PM
