Primary cover
Old Jan 24, 2010 | 10:56 AM
perpulreaper's Avatar
perpulreaper
Default Primary cover
I'll be replacing my cover soon with a chrome one i fond was wondering if there is a pattern to the bolts and what tork they should be tightened to
cant find anything in my service manual
all so what gaskets do you all recommend and what is the name of the bearing i need for in my cover so i don't ask for the wrong one
thanks
Old Jan 24, 2010 | 05:09 PM
t150vej's Avatar
t150vej
Just go around them in light steps. I usually start in the middle and work out to the ends, but no biggie. About 8 ft/lb is all they'll stand. Primary gaskets cost too much no matter who makes them and no matter the brand, they won't have the extra bar made for the corner at 10 o'clock of the clutch area. James used to, but they either don't make them or nobody carries them. If they do, it's James# 34901-79A or DS# 174321, If you can't get that one, just go with OEM.
Starter shaft bearing OEM# 9063
Old Jan 24, 2010 | 05:35 PM
perpulreaper
thank you
Old Jan 24, 2010 | 08:41 PM
I8SMK4U's Avatar
I8SMK4U
I did mine, easy. Just common sense, lightly tighen them going from one side and crossing to the other, but use an inch/lbs torque wrench. It says in Clymers manual what to do it at. I think its like 24"/lbs. I think I used a Cometic gasket, metal in the middle and black on the outside. I got an "/lbs torque wrench at Harbor Tool and freight, I probably use it more than a foot/lbs torque wrench on my bike.
Old Jan 29, 2010 | 10:20 AM
wulffe's Avatar
wulffe
My FSM shows the torque at 7-9 ft/lbs. (Page 6-1)
Old Jan 29, 2010 | 12:12 PM
legacycycles's Avatar
legacycycles
Oops
I normally do about 90-100 inch pounds.With blue loctite.And use a criss cross pattern.As for gaskets,cometic or H-D.
Old Jan 29, 2010 | 02:46 PM
perpulreaper
thanks everyone got my gaskets and my starter bearing now just need the time and a little warmth in the man cave
Old Jan 29, 2010 | 07:13 PM
Buddy WMC's Avatar
Buddy WMC
Do as T150 suggests 110 -115 inch pounds maximim, do not use a foot # torque wrench. If you can find a Cometic primary gasket they are the best. In most cases they can be used twice before they are a throwaway. They are a bit more expensive, but do not leak.
Old Jan 30, 2010 | 07:52 AM
EVOrider's Avatar
EVOrider
You can use a foot lbs. torque wrench. Just make sure you convert feet to inches!
Old Jan 30, 2010 | 11:08 AM
Buddy WMC's Avatar
Buddy WMC
Yes you can, but you loose the feel. Most foot # wrences are 1/2" drive. The inch # wrench is 3/8" drive. There's difference in the length of the wrench and therefore the feel. Both my foot # and inch # torque wrences are calibrated and match my partners. That way we know they are right.
