Re-jetting
the short pipes are only good for top end.
I have an fxr and I run a thunderheader with a screamin eagle air cleaner.
42 was way too lean on the pilot for me. I think I actually had a 185 main.
You really should think about a different exhaust. I ride on the street alot and the thunderheader gives alot of low/mid range and actually utilizes the cam I put in my bike.
Do you have any pop on de-cel?
oh just an FYI, any more than 2 turns out on the mixture screw, you really should go up a size on the pilot jet.
To the guy with the hypercharger. I had one of those on my 95 fat boy. I actually lost power with it. and 2 1/2 turns out on mixture screw, go up a pilot size.
I rejet alot of carbs, most of the time if done right, you really shouldn't have to mess with mix screw.
I live in Massachusetts and I get them as close as I can. the weather isn't a constant temp here, sometimes it's tough.
I got the Short Shots so I could ride them until I found a used Thunderheader. The bike, as of last night, has a Screaming Eagle intake (Ebay find) and now the Thunderheaders off a Softail. Rode it around the neighborhood at midnight last night and it didn't get warmed up, so I will have to wait until Monday to ride it due to typical Oklahoma May weather.
