Old Evo
Old Apr 24, 2010 | 07:17 AM
TedMan's Avatar
TedMan
Default Old Evo
Some questions for the group. I'm seriously thinking of buying a 1986 Touring FLHTC with 50,000 miles on it. It has had new rings and top end gaskets, and a Mikuni carb, but aside from that nothing else. Looks to be well maintained, no rust or leaks that I can detect. What should I be on the look out for/problems with the old Evos, and if I buy it what should I have done to it, if anything, to avoid problems in the future. Thanks for any and all input.
TedMan
Old Apr 24, 2010 | 08:15 AM
hotrod351's Avatar
hotrod351
only thing would be the price. 86 id say 5-6 thousand. after all today you can pick 2002 and newer for $10,000.00 and for the four thousand more youd be getting much more bike, so thats why i figure the 5-6 for a 86.
Old Apr 24, 2010 | 08:28 AM
t150vej's Avatar
t150vej
TedMan
As with anything mechanical, things can go wrong at any time without apparent cause or reason and there are a number of things that can fail with the Evo family of bikes, most of which are related to maintenance and/or operation. But to answer your question... there really isn't a "common denominator" of failure for that year model of FLH. That is to say, there is no part of that bike that is definitely going to fail.
But a few of the complaints about Evos you may hear are; leaking cylinder base gaskets, bad lifters, swingarm bushings that can flex enough to cause less than perfect handling and electrical system deficiencies that can cause some minor problems (which can be said of any older machine). There are a few others, but they are year model specific regarding engine cases and cam bearings, none of which apply to the '86.
Enjoy your new ride and welcome to the Evo side...
Old Apr 24, 2010 | 08:39 AM
Dr.Hess's Avatar
Dr.Hess
I don't consider 86 "old."
Anyway, by now and 50K miles, any minor BS problems it might have like the base gaskets has been taken care of. That one already has ditched the POS OEM carb. 50K might be getting near time for a clutch, and look at the belt condition. But these are normal wear items. The only really recurrent issue I've had has been the speedo cable and sender, and I'm doing OK with my genuine HD parts on there right now. Oh, and look at the crossover exhaust pipe coming off the rear cylinder. They shatter under the cover. You can't see it and it will give you problems. Ask me how I know. Also unobtainium now, so you have to swap the exhaust out to a new twinky system as shown in the above pic. I could post my full maintenance log for the past 24 years. It's mostly oil changes, tire changes, and a new battery every 2-3 years plus the speedo cable/sender as mentioned.
Old Apr 24, 2010 | 08:50 AM
Idaho Scootertrash's Avatar
Idaho Scootertrash
HR351 is correct about the pricing. Definitely not more than $6K.
The good: The early Evo engines ('84-'89) are considered the best Evo's made. Bear in mind, this is just an opinion! They essentially had a Shovel lower end with Evo jugs and heads. The crank breather is/was the same as a Shovel (vented through the lower end, not the heads via an umbrella valve like later models). The early Evo's also have a reinforcement for the crankshaft bearing set in the left side case. Later versions didn't have that. If the mileage stated is correct and it just had an upper end done, that engine will (should) last another 50K without missing a beat. Don't let "high mileage" scare you away. A low mileage Evo is getting as rare as a barn find Knucklehead.
The potentially bad: If it has the stock ignition, I'd ditch it. I had an '85 FXEF and had some drivability issues that all cleared up once I dumped the OEM ignition for an aftermarket one. I went with a Dyna S dual fire because of simplicity and cost but there are many more choices today.
I'd go over the wiring harness. With a bike that old the wiring will tend to get brittle, conductors will get corrosion creeping into them, contacts in switches get corroded; you get the idea. I'd just look it over carefully for those types of indicators.
One last thing....take a look through an aftermarket catalog for those parts that you may be changing and ensure that they still have what will fit on your bike. That's a good way to figure out 'what fits what'.
Good luck with it!!
Old Apr 24, 2010 | 09:32 AM
Dr.Hess's Avatar
Dr.Hess
Oh yeah. The Dreaded Click. An annoyance, really, but they all do that.
Old Apr 24, 2010 | 09:44 AM
Scudder's Avatar
Scudder
What he said. 1986 was 24 years ago, but the EVO is not an old motor in my book. I have had several EVO bikes and have done many repairs/upgrades to them. They are pretty easy to work on and are very reliable. I will continue to consider them very desirable and other than a trashed and beat up bike, I would buy another and be confident that it will do what I ask it to do. And as far as the ignition is concerned, I'm running points in my '93. I fried an electronic setup last summer on my way to Tennessee and have put 5000 miles on the points since without a single problem. But that's just me. Scudder
Old Apr 24, 2010 | 09:51 AM
grbrown's Avatar
grbrown
I bought my 1990 FLHS new and had a few problems early on, but the replacements have all held up, I haven't had any repeat problems. Those sorts of thing should be done and dusted by now. I don't think there is anything we can't fix between us on your 'new' bike! Keep us up to date on developments and post pics.
Old Apr 24, 2010 | 11:05 AM
Dr.Hess's Avatar
Dr.Hess
Lifters have probably been replaced too, but they go out by then on all Evos. I did mine at about 70K miles, and the cam was trashed then too so I put an EV1 in. 86 does not have the "bad" inner cam bearing.
Old Apr 24, 2010 | 11:55 AM
TedMan's Avatar
TedMan
Wow, thanks all for replying so quickly. I very much appreciate your perspective and advice on pricing. I looked up Kelly Blu Book and you guys were right on, about 6,000. I'm going to give this serious consideration. Thanks again.
TedMan
