drive traiin issues for EVO
My next scenario relates to a problem I am having when I try to accelerate from a stop. The clutch seems to work fine, I let out the clutch, hop on the gas and the bike starts to shudder or buck. This happens in 1st through 3rd gear and sometimes in 4th. I have a 6 speed belt drive ultima transmission. Any thoughts will be greatly appreciated.
Reminiscent of problems I had a few years ago, which when the bike finally expired proved to be the ignition sender inside the conical timing cover. But it could be a variety of other things. Check your VOES and the small pipe to it, which can mess with the timing. The VOES is mounted under the gas tank on the bracket between frame and heads and has a short thin tube to the inlet manifold.
Other than that, check the basics, such as clean the carb float chamber, gas tank filter, to make sure there is no fuel supply problem. These thingsa can be a devil to chase down sometimes. Keep us posted!
+1 on this. Great power.........struggling..........great power........struggling..........Fuel filter or carb issue is where I would start. Stabil is nice but debris is debris!
