Finding neutral
Old Aug 4, 2010 | 10:14 PM
1997bagger's Avatar
1997bagger
Blip the throttle and catch neutral on the way up or back down, synthetic trans fluid help a little, atf in the primary helped a little.
Old Aug 4, 2010 | 11:36 PM
IronGear's Avatar
IronGear
Smile
Originally Posted by Nautilus
My 1995 fatty doesn't like going into neutral, always wants to stay in gear ready to get going again lol
I have to blimp the throttle sometimes, and sometimes not... it's quite normal on Harleys to have a hard time finding neutral...
Best fix... never stop, that way u don't have the need to find it
It is completely NOT normal to have trouble finding neutral on a harley
It may be common and usual, but it is not normal.
A 95 model should (and can) find neutral very easily.
As can an 85 model.
Old Aug 5, 2010 | 06:17 AM
Tom84FXST's Avatar
Tom84FXST
Originally Posted by Doug S
Oil that is too heavy or over full in the primary will cause that trouble,
I run heavy gear oil in my primary and it goes right into neutral...no problems. I find that most times the culprit is a too tight primary chain...you must find the tight spot in the chain before adjusting it.
Old Aug 5, 2010 | 08:01 AM
carlgrover's Avatar
carlgrover
My 98 goes into neutral fairly easily if it is still rolling. When stopped it can be a pain.
Old Aug 5, 2010 | 09:18 AM
grbrown's Avatar
grbrown
That's the same with my 1990 Glide AND 2003 Dyna! The Dyna is not so bad I must say, but not perfect. My Buells have not had the same problem, so it seems to be big twin related.
If any of you chaps who reckon it can be adjusted right would like to pop over I would be obliged!
Old Aug 5, 2010 | 09:23 AM
Dr.Hess's Avatar
Dr.Hess
I'll give it a try, Graham. Send me a ticket. And I want to tour Hethel while I'm in the neighborhood.
Old Aug 5, 2010 | 09:34 AM
Nautilus's Avatar
Nautilus
Red face
As can an 85 model.
So much ppl claim to have at least some trouble finding it don't they? would that make it common enough as to be considered normal for a harley since they haven't actually adressed this issue?? :P
My dad's 05 RK had the same ability to "find" neutral as my 95...
Everyone I've rode with and know of has spent half a minute or more searching for nuetral at some point... even new bikes right out of the dealer...
I've come to condier it more of a harley trait... such as the loud "clank" when shifting to first... doesn't sound right... we all know that, but it's still there after year and year and model and model...
bottom line is... it's not a real worry for most of us unless we CAN'T find it...
btw... forgot about a little hint.... when ur in a stop light and wanna go for neutral... go all the way to first and then gently tap it the lever up (or down on the heel shift) and it should be easier to find it...
Old Aug 5, 2010 | 01:26 PM
Tomcatt78's Avatar
Tomcatt78
I did put a new drive belt on and it could be a little too tight. I've done some research on belt tightness and there doesn't seem to be a clear answer. The deflection should be around 5/16 to 3/8 with 10lbs pressure at the tightest spot. I called a dealer to see if they have a tension gauge but they didn't. How do you find the tightest spot though?
Old Aug 5, 2010 | 01:31 PM
ToXiK's Avatar
ToXiK
about the only time I can find "N" is when I am shifting from 1st to 2nd....
Old Aug 5, 2010 | 03:37 PM
grbrown's Avatar
grbrown
Thumbs up
Drat - didn't reckon on being taken up on that! You'll want to see around the Formula 1 team HQ as well, I imagine?!
....when you're in a hurry!
