Finding neutral
Old Aug 18, 2013 | 03:08 PM
  #41
Joe_G's Avatar
Joe_G
Originally Posted by texashillcountry
When you say unscrewed the adjuster are you talking about loosening or tightening the cable?
The adjuster adjusts the cable housing, not the cable itself. I made be housing a little longer which has the effect of making the cable shorter and thus disengages the clutch more when the lever is fully pulled in.
Just got back from a cruise, it's 100% better than before, neutral is now easy to find now that the clutch isn't dragging.
Old Aug 18, 2013 | 04:41 PM
  #42
Dr.Hess's Avatar
Dr.Hess
Just make sure that when the clutch is engaged (clutch lever all the way out) that there is some free play in the lever. That is, the lever is loose so that the throw out bearing isn't being ridden.
Old Aug 18, 2013 | 04:54 PM
  #43
Joe_G's Avatar
Joe_G
That's a good point. I've still got 1/8" free play or more at the lever.
I come from the c5 & c6 Vette world, if our clutches don't disengage properly it wreaks havoc on your blocker rings.
Old Aug 18, 2013 | 05:43 PM
  #44
Jasper86's Avatar
Jasper86
this thread motivated me to actually check into my neutral-finding-issues.
cable was good...hrm, maybe primary was overfull,easy enough to check. pulled the derby cover and was greeted by a deluge of motor oil.
guess i wasnt blowing it out past the breather after all. also explains why i mysteriously went through a quart and a half of oil in 1 long trip, and havent lost a drop since (filled the primary).
ahh well. outer primary is off, clutch plates are out, letting it sit a while to drip/drain some more before I attempt to pull the compensator/clutch hub.
Old Aug 18, 2013 | 05:58 PM
  #45
bluharley's Avatar
bluharley
Well...that's not good.
Old Aug 18, 2013 | 06:02 PM
  #46
Jasper86's Avatar
Jasper86
well, main seal was done 6months ago when my indy did my chain conversion for me. also did the S&S race...so not sure why this failed. doesnt really matter now....gotta fix it.
Old Aug 19, 2013 | 10:11 PM
  #47
Jasper86's Avatar
Jasper86
well, this explains a lot
probably blew it out when i cracked a piston a few months back. 60% leakdown on 1 cylinder put a LOT of extra pressure into the crank case.
upside now, neutral is easy to find, shifts are smoother, and WAY less vibration/clutch dragging.
Old Sep 26, 2013 | 06:06 PM
  #48
Joe_G's Avatar
Joe_G
Finally read the owners manual....turns out the transmission is designed to only go to neutral from first...it won't go into neutral from second.
I noticed now that I've adjusted the cable and try to go from first, my bike hits neutral easy now.
Old Sep 27, 2013 | 05:12 AM
  #49
grbrown's Avatar
grbrown
Wink
Having owned my 1990 bike from new I had forgotten that feature! It's second nature. It has the benefit when changing down to first gear, for example to take that unbelievably tight and steep hairpin bend, that you get the gear and not neutral!
leachman
May 28, 2018 09:30 AM
Classic Beast
Sep 22, 2016 07:50 AM
lineman06
Jul 26, 2016 08:43 PM
dustydog2
Nov 3, 2013 04:29 PM
Taterdog
May 6, 2007 01:11 AM
