1998 Evo build help please??
Old Dec 7, 2010 | 02:34 PM
GREENOHAWK69's Avatar
GREENOHAWK69
Hi STL,
I have a '97 Wide Glide (Evo) and followed this website: http://www.nightrider.com/biketech/hdbuildstage3.htm and their Stage 3 Evo Build (~ 82hp).
There is a second Stage 3 build (~ 95hp): http://www.nightrider.com/biketech/hdbuildstage3_95.htm
I have talked to Stephen Mullen whose bike this was performed on. He is also friends with Wes @ Cycle Rama as OldBiker provided the link. You can some pretty big HP/TQ builds that Cycle Rama has done.
Since I have a '97 Evo I will list what I did (so far - it is not enough, imagine that LOL), following nightrider.com's list of parts:
* SE A/C, w/ heavy breather
* Thunderheader 2-into-1 exhaust
* Cams - I believe they are EV-27, but were installed prior to me buying the bike
* SE Heads (increases compression to 9.5:1)
* Adjustable pushrods were already installed
* SE Ignition (non-adjustable)
* Top end gasket (it may be Cometic)
This resulted in 79hp/87tq for my bike.
Good luck on your build and keep us in the loop. Post dyno when done with parts in your build.
Old Dec 8, 2010 | 12:43 AM
1997bagger's Avatar
1997bagger
Originally Posted by miacycles
Heads done wrong will cost you HP and Torque. Sach's out of Florida does very nice work with really good results, and there are lots of others.
2 really good peices of advice in this statement about headwork and John Sachs. John did my heads and helped me set my engine up, straightshooter and respected by the best.
Rockwool
Custom Models
Feb 16, 2013 03:27 PM
buddah1972
Feb 15, 2013 01:05 PM
Rockwool
Screamin Eagle CVO Models
Feb 10, 2013 11:11 AM
RidemyEVO
EVO
25
Jan 7, 2010 04:14 AM
98kingflh
Feb 16, 2006 01:57 AM
