Dangerous Talk in here
Old Jan 22, 2011 | 02:06 AM
Wingnut3's Avatar
Wingnut3
Question Dangerous Talk in here
This is my first HD (95 RK) so I've read countless oil threads, debates, and arguments spending hours of research. I've decided on M1 15W50 full synthetic for the crankcase, ST3614 or ST3600 for a filter, and Super Tech 75/140 full synthetic gear oil for the transmission. Now here's the dangerous question. Between me and my dad we ran a 1983 Goldwing 170,000 miles on Hondaline GN-4 10W40 with the origional wet clutch it came from the factory with. Has anyone run this in their primary? It costs about the same as Formula Plus, but I think it might be an alternative to Chavez.
Old Jan 22, 2011 | 04:13 AM
Brettfullthrottle's Avatar
Brettfullthrottle
Run ATF! Yeah....here starts the debate!
Old Jan 22, 2011 | 06:46 AM
EVOrider's Avatar
EVOrider
I've tried synthetic in my EVO's and for some reason....the EVO didn't like it. It seeped more and the engine seemed to make more noise.
As for the Primary.....just about anything works in there. The clutch seems to like the ATF better than anything else I ever tried.
As long as you have gear oil in your transmission....you're good to go.
Old Jan 22, 2011 | 06:51 AM
Mike T's Avatar
Mike T
Just as evorider said,stay away from the synthetic oil.
Old Jan 22, 2011 | 07:36 AM
bikerlaw's Avatar
bikerlaw
I'm a recent convert to Ford ATF in the primary. Very happy with it thus far. The only oil I have ever put in any hole that had actual and immediate improvements that, as the rider I could feel.
Old Jan 22, 2011 | 07:50 AM
astark's Avatar
astark
I'm certainly no expert and many here are way more knowledgeable than me. But when I bought my bike I asked the previous owner what he had run and found since birth (1999) only non synthetic HD fluids had been used, so I stuck with that.
I do change my fluids way more often than necessary, but that is more for the fun of it than anything else, and I have never had a fluid related problem of any kind.
Old Jan 22, 2011 | 07:56 AM
astark's Avatar
astark
Just wondering which Ford ATF you are using and what kind of difference you immediately noticed.
Old Jan 22, 2011 | 08:04 AM
Dr.Hess's Avatar
Dr.Hess
I ran only HD fluids in all holes for a couple decades. My stash of primary fluid finally ran out and the MoCo doesn't make primary fluid anymore, so I switch to Mobil 1 ATF. I also switched the transmission to Mobil SHC630 at the same time, and between the 2, my bike shifts better than it has since new.
My bike also does not like fully synthetic motor oil. Makes all kinds of funny noises. I stick with the HD "dino" blend oil. Oh, and a Honduh "wing" is water cooled, remember, and a Honduh, so it's going to behave differently than our bikes. We also never have to replace a water pump.
Old Jan 22, 2011 | 08:37 AM
M&D88FXSTC's Avatar
M&D88FXSTC
in an emergency I put some H-D 20/50 in the primary & it made the clutch slip. I tried to tighten it up to no avail. Went back to Spectrol (I think) primary fluid, all we had local & slipping went away.
just my $.02
Old Jan 22, 2011 | 10:13 AM
big cahuna's Avatar
big cahuna
I've run Harley oil, ansoil, and diesels specific oils in my primary. I didn't notice any difference in feel or performance between Harleys oil and amsoil20/50 wt oil. The 15/40 wt diesel oil I believe has less drag an the clutch plates and it seems to have a better shift feel to it. By that I mean I don't get the standard bang into fist gear, and shifting is just about as quiet as it can get. I also believe you will have less wear on the chain and gears in the primary with oil, over auto trans fluid.,,
