Cam break in question.
Old Feb 27, 2011 | 09:46 PM
hatchetman's Avatar
hatchetman
Default Cam break in question.
Doing a re ring on my 88 FLHTC 80 ci with 50,000 miles on the clock. I pulled the cam & lifters. They were still in good shape but a small amount of wear was visible. So Im installing an EV-13 new lifters & adjustable push rods as it goes back together.
Now, on a car when you fire up you run the rpm steady for 15 minutes to get your initial wear in or break in. on my Chevy, I run it around 1500.
Is there a proper break in proceedure on an Evo?
I know how to seat the rings but not sure on the cam & the manual does not cover this question.
Hatch.
Old Feb 27, 2011 | 11:10 PM
gsxrboy96's Avatar
gsxrboy96
cam needs no break in, simply because it is a roller, not a flat tappet like your chevy, only thing you need to worry about is doing a initial heat cycle on the rings, if you used a cast ring, they almost seal immediately. chad.
Old Feb 27, 2011 | 11:16 PM
RidemyEVO's Avatar
RidemyEVO
Can't say I ever heard of a break in procedure for lifters or cam. Lifters may be a bit noisy first time you startup but should be good after.
Old Feb 28, 2011 | 12:12 AM
hatchetman's Avatar
hatchetman
I prolly won't hear the lifters due to the yee hawwww's when she comes back to life! I need to ride soon or I will go insane.
Just read an interesting bit on making more power, Here's the link.
http://www.calsci.com/motorcycleinfo/HP2.html
thanks for the input!
hatch.
texashillcountry
EVO
40
Mar 21, 2017 06:14 PM
johnod
EVO
Mar 11, 2017 05:19 PM
RYGUY73
Dec 8, 2012 12:20 AM
lieutenant G
EVO
18
Jul 28, 2012 08:18 PM
73HDFX
Shovelhead
Jul 1, 2011 11:59 AM
