Adjustable push rod question?
Old Mar 3, 2011 | 02:57 AM
ionhd's Avatar
ionhd
Default Adjustable push rod question?
I understand setting up adjustable pushrods when the tappets need to be left to bleed down.
My question is when fitting NEW hydraulic tappets/lifters how should the pushrods be set?
I assume new tappets will not bleed down; therefore I think that adjusting them so there is no free play in the valve train would be the best way to go, please give me your advise on this subject because I am not sure.
Many thanks for any information.
Old Mar 3, 2011 | 07:33 AM
V-Twins & Bowties's Avatar
V-Twins & Bowties
Same way.
Old Mar 3, 2011 | 07:34 AM
V-Twins & Bowties
You ought soak em or put them in oil and pre pump them up before installing though.
Old Mar 3, 2011 | 09:54 AM
RidemyEVO's Avatar
RidemyEVO
I soaked mine for a while before installing them. I think there going to pump up as soon as you start the motor anyway although they may be noisy for a second or two.
Old Mar 3, 2011 | 10:41 AM
ionhd's Avatar
ionhd
Thanks for the info.
Mberlin74
Engine Mechanical Topics
Oct 18, 2016 08:36 PM
adm
Jan 13, 2016 07:56 AM
ionhd
Exhaust System Topics
Mar 3, 2011 10:42 AM
sneeky7374
Shovelhead
May 3, 2010 08:23 PM
FNFLH
Shovelhead
Oct 6, 2006 12:48 AM
