Banjo Bolt Problems.
Old Mar 9, 2011 | 12:14 PM
Tom84FXST's Avatar
Tom84FXST
Originally Posted by Dr.Hess
If the bore is the same and the leverage is the same, then both units should function the same from a hydraulic standpoint.
Just a thought: take a sharp 7/16" drill bit (if they have those over there) and run it through your banjo bolt.
12mm will work fine...you have nothing to lose to try it...as long as you have the correct bore it will work fine.
Old Mar 9, 2011 | 01:41 PM
Big Gee's Avatar
Big Gee
Thanks for all the input folks. Gonna get a 12mm bolt and go with new cables. Cheers.
Spike883
Apr 18, 2016 03:18 PM
freedom416
Oct 8, 2015 12:06 PM
goatfarmer
Mar 10, 2015 04:12 AM
r46jack
Feb 2, 2012 03:04 PM
02Ultra EG
Apr 26, 2008 09:12 PM
