Dead evo!
Old Mar 24, 2011 | 09:01 PM
hotrod6779's Avatar
hotrod6779
Yeah I hope so too. Trying to come up with me a manual. See how it goes from there.
Old Mar 25, 2011 | 03:27 AM
alaskajeff's Avatar
alaskajeff
My motor went south (lifter falure) at the end of last summer. I'm knee deep into my rebuild. NEVER worked on a Harley motor before, but with the right manual I can tear ANYTHING apart......Now putting it all back together is another story. Take your time and it might just be something simple.
Old Mar 25, 2011 | 06:01 PM
miacycles's Avatar
miacycles
Hotrod, to check the compression, get the engine warm, pull the plugs, ground out the spark plug leads, hold the throttle full open and crank the engine over4 or 5 time without stopping, watching the compression gauge. Oh ,make sure the bike is in neutral as it will make the task much more difficult!!! LOL If the reading is still low try putting a little oil in the cylinder to see if the compression goes up. If it does then the rings are the culprit.
Old Mar 25, 2011 | 07:26 PM
Moog Player's Avatar
Moog Player
And if the pressure doesn't go up, it's the valves.
(Mine was 100 front and 98 rear last weekend when I checked it. Stock motor.)
Old Mar 25, 2011 | 07:37 PM
Beemervet's Avatar
Beemervet
Originally Posted by emwolb
i was planning on sending it off and doing the harley remanufacture program. it costs $2395 and i can haul the motor up to the harley shop and in a couple of weeks i get basically a new motor.
I thought part of the deal is that you have to pay the dealer to R&R the motor.
Old Mar 25, 2011 | 11:06 PM
hotrod6779's Avatar
hotrod6779
That's my biggest trouble. They aint no warmin up. Poor old gal's dead. A friend of my father in law is gonna come look at it next week. See if maybe he can help. I can't go too far with it. Got a little one on the way. This is my first bike. I bought it in December, Rebuilt the tranny in January, found out I was having a Baby in February(The misses is having it, I only helped with the fun stuff), and killed the motor in March. Can you hear the violins! She wants me to sell it. It sits in the garage where her new car goes until it's fixed. Got big feet. I'll put em down where, when, and how I want to.
Old Mar 26, 2011 | 05:02 AM
RidemyEVO's Avatar
RidemyEVO
Hotrod, I like these Evo's because they will run no matter how tired and worn the engine is. If you got battery well charged fuel going to intakes and good spark it'll go ( kind of reminds me of the old brits ). You didn't say whether you checked the pushrods for tight/loose. Check for spark? Accel pump spitting fuel in carb? One step at a time, these bikes are straight forward.No manual needed for above mentioned.
Old Mar 26, 2011 | 07:27 AM
hotrod6779's Avatar
hotrod6779
I checked all of the above with the exception of the tightness of the pushrods. How would a fella go about doing such a thing.
Old Mar 26, 2011 | 08:41 AM
houseoutnumbered's Avatar
houseoutnumbered
Good luck it sounds cam bearing has taken a dump on you.
Do a leak down test and check you push rods.
Old Mar 26, 2011 | 08:42 AM
miacycles's Avatar
miacycles
Pull the plugs, pop the covers, put the bike in top gear, roll the bike forward until the lifter you are checking is all the way down. You should be able to spin the pushrod and not have any noticeable play in it. Let us know what you find and we can go from there.
