Vibration in FXR
Old May 6, 2011 | 05:12 PM
lurchus's Avatar
lurchus
Default Vibration in FXR
I've got a '87 FXLR that vibrates. Not as bad as a Sportster, but a lot more than my '03 FXDWG. Anyone have experiance with this? Maybe needs new motor mounts or stabilizer links?
Lurchus
Old May 7, 2011 | 02:40 AM
Spanners39's Avatar
Spanners39
It probably needs some fettling in that dept but it will never be as smooth as your 03.
Old May 7, 2011 | 09:44 AM
magna's Avatar
magna
If the rubber mounts are original from 87 i would definately say they could be the problem.
Old May 7, 2011 | 04:45 PM
Rider1000's Avatar
Rider1000
In my case it was a worn-out front motor mount. I got 10k miles out of the original mount before it went. The problem was the weight of the engine moving the mount caused the rubber to weaken. I had thought that Harley redesigned later mounts because comparing the old and new the front bolt holes were located lower on the new mount, but it's really because the rubber on either side of the threaded bolt holes weakened. It's tricky because the mount can look fine, or even like brand new in my case, and still be worn out. When the rubber weakened it caused the inside rubber part to be permanently grounded against the frame transmitting the engine vibrations.
guido4198
EVO
79
Jul 24, 2019 06:06 AM
davic666
Custom Models
May 14, 2017 07:02 AM
atengnr
Shovelhead
Apr 20, 2016 09:31 PM
89 FXRS
EVO
14
Dec 17, 2007 12:48 PM
