92 heritage softail classic
Old May 18, 2011 | 10:47 PM
harley7316's Avatar
harley7316
Default 92 heritage softail classic
Hi was wondering i want to take of the spot lights and turn signals and keep the side strips but it looks like the spot lights mounting bars is attached but i cant see how its attached it looks like it should come apart from the side rails?Any ideas?Thx
Old May 19, 2011 | 11:27 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I have a '95 FLSTC and mine are connected with a bolt. If you don't want the driving lamps all you have to do is remove the bolts and the wiring harness and put the bolt back in. You might have to use a shorter bolt.
Old May 20, 2011 | 02:28 AM
harley7316's Avatar
harley7316
Well i tried that but looks like the piece that is attached to the light bar is fused to the chrome side rail were the bolt go through to the triple tree i take the bolt out and the light bar bracket doesnt want to come apart from the chrome side rail i cant see how it would be attached but cant pull it apart ?
Old May 20, 2011 | 10:07 AM
texashillcountry
Dirt don't hurt
It should fall right off. Maybe it is simply held on with friction. I would try a rubber mallet or a piece of wood. IE place a 2x4 at hte joint and give it some taps and see if it breaks free. That way you don't damage any of the chrome.
Old May 24, 2011 | 11:31 AM
95yj's Avatar
95yj
Yea, what TX said. I have a 93 which is identical to yours and the bolt on either side is all that holds it on. (They're all pretty much the same anyways.)
Scudda
Apr 4, 2018 06:20 PM
bvette94
Feb 15, 2011 06:34 PM
03dragonRK
Jan 26, 2011 06:30 PM
freshman
Jun 15, 2010 05:12 PM
