Idle
Old May 26, 2011 | 08:15 AM
mballinger's Avatar
mballinger
6th Gear
I take it ECM and fuel pump fuse are the only 2 fuses that under that cover? The only reason I ask is that there are only 2 fuses but the lables seem to be on the other side of the panel from where the fuses are. Do I have to have the run on as well when I do the on/off seq?
Old May 26, 2011 | 10:59 AM
ajayrk's Avatar
ajayrk
Yes the run switch on. The IAC has to learn the new stetting, fully extended then fully retracted and then a few steps out for the start position.
There should be a 15 amp (fuel pump) and a 5 amp(ECM) fuse.
Old May 26, 2011 | 11:42 AM
mballinger's Avatar
mballinger
6th Gear
Ajayrk, sorry if I messed something before, what am I going to fully extended and fully retracted and then a few steps out for the start postion? Do you mean the throttle? Does the engine need to be running when I do this or before and does the switch need to be on?
Old May 26, 2011 | 01:50 PM
ajayrk's Avatar
ajayrk
The idle air control motor. With out starting the engine and the run switch on switch on the ignition. The idle air control motor is a stepper motor and will step out enough revolutions to crack the throttle plate open for starting. As the engine warms up it will step in reverse to close the throttle plate. When the engine is shut down the stepper motor will step enough to reach zero steps and then step out enough for the next starting sequence. Watch the stepper motor when you turn the ignition on and off.
The stepper motor sits on top of the throttle body. You may have to remove the air cleaner box to see it operate if you can't see it from the throttle cable side.
Old Jun 1, 2011 | 01:07 PM
mballinger's Avatar
mballinger
6th Gear
Thank you to everyone who posted for me. I tired some of the ideas that were given, but the sitaution only got worst. To make a long story short, I engine light kept coming on, the front head started leaking oil from the top somewhere in the middle of the head and saturated the whole engine, the idle started going up and down again that started the whole mess and it sounds like there is an intake air leak. Everything that is going on with it I decded to take it to a dealer and let them figure it out.
I have to say this, the old girl got me home all the way from Orlando Fl to Cental Ohio. Total miles for Trip: 2650 for everything else there is Master Card!
Les Duncan
Sep 25, 2023 12:26 AM
Bogey_52
Dec 1, 2016 10:08 AM
jntroese
Engine Mechanical Topics
Jul 16, 2016 09:48 AM
skratch
Jun 3, 2009 03:03 PM
1nuckenfut
Exhaust System Topics
May 28, 2007 03:12 PM
