carb help
Old May 30, 2011 | 01:06 PM
gsxrboy96's Avatar
gsxrboy96
Default carb help
Ok, need a little guidance, I have a 10.5 to 1 eighty inch, and I always like using cv carbs, but this one is doing something I can't figure out, in high gear, the bike is just flat, between 55 and 70, the bike is a turd, after 70, its a missle, so with that being said, should I change the needle and main, just the needle ? Lean it out or fatten it up ? What's your thoughts, its currently netted at 50 pilot, 195 main, and a bob woods kt1 needle ....
Old May 30, 2011 | 01:10 PM
96roadking's Avatar
96roadking
pilot too big, or needle position wrong would be my 1st guess
Old May 30, 2011 | 02:07 PM
gsxrboy96's Avatar
gsxrboy96
would the pilot effect a/f around 2500-2800? I know the needle would, I guess I'm gonna try one of those sportsmen needles since they're adjustable
Old May 30, 2011 | 02:49 PM
miacycles's Avatar
miacycles
with stock spring and slide an 80" will transition around 2500. Remember even above that the pilot jet is supplying about 10% of the total fuel used. If you have a lighter spring/slide or have the slide drilled, it can be opening too fast and this will cause a "flat spot" until the engine gets farther up the RPM scale. Too much cam or timing off could also be the problem. Oh make sure the carb is squeaky clean, if a transition slot or air bleed is obstructed you will have a problem like the one you mentioned. Hope this helps.
Old May 30, 2011 | 02:51 PM
Holster Maker's Avatar
Holster Maker
IMHO....your jets are fine, start out on your mix screw 1/8 t @ a time, if no help raise your needle one notch (move cir-clip down), if you have adj needle.
If that doesn't do it, go to 52 mid jet, you are lean!
Remember a little LEAN will Kill hp, ..a little rich does nothing but burn more gas....to a point a course!
I have everything totally adjustable on my "Killer Perf Carb" and you can fine turn the cv carb like you can't believe.
my 2 cents from past experiences
Old May 31, 2011 | 08:22 PM
the blob's Avatar
the blob
id think the pilot is also too fat. id do some plug chops.
zakaria777
Carburetor Related
Oct 9, 2015 07:18 PM
0maha
EVO
Sep 4, 2014 09:37 AM
Khshockey44
Exhaust System Topics
Feb 10, 2013 01:15 PM
jaws134
May 23, 2006 12:39 PM
HDF Tech
Carburetor Related
Mar 19, 2006 10:08 PM
