Looking at doing a open primary on my 88 FL
Old Jul 16, 2011 | 02:13 PM
highmarkxx's Avatar
highmarkxx
6th Gear
Default Looking at doing a open primary on my 88 FL
Hey guys im looking at doing a open primary on my 1988 FLT Evo and every open primary i have seen is for 90 up? I have read it has something to do with a splined shaft on the trans vs a tapered shaft on the trans? any help would be greatly appreciated.
Old Jul 24, 2011 | 09:45 PM
highmarkxx's Avatar
highmarkxx
6th Gear
Nothing?
Old Jul 25, 2011 | 03:15 AM
Spanners39's Avatar
Spanners39
90 up is the splined clutch for sure but you see open primaries on Shovels so they must be available, you just looking up the wrong model.....try looking under Shovelheads.
Old Jul 25, 2011 | 06:18 AM
bikerlaw's Avatar
bikerlaw
I think the FLT uses the same short primary as the FXR....I think. The reason I say this is my buddy has an 80's FXR and he is trying to do a belt drive on it as well. We went to Departure (a local Indy here in Richmond), and he found two company's that did make them for that setup. Both setups were just over two thousand dollars, AND you needed to buy a late model starter as well. For the life of me I can't remember for sure the two companies who made them, but I remember the prices quite well. I think in your case I would call Karata, Primo, and BDL directly and ask for part numbers, you might be OK. I would not trust the people who answer the phones at Jireh and JPCycles. I would give THEM the part numbers and ask if they could get it once I had them from the manufacture.
__________________________________________
Old Jul 25, 2011 | 12:37 PM
2006FLST's Avatar
2006FLST
I agree with bikerlaw. I would call BDL or Primo.
Old Jul 30, 2011 | 11:48 AM
highmarkxx's Avatar
highmarkxx
6th Gear
Ok thanks guys i will give them a call,I just want a direct bolt on setup no having to hunt down parts.
Old Aug 5, 2011 | 10:30 AM
FXSTS93's Avatar
FXSTS93
I have a 3" BDL on my 93 Springer.
http://www.beltdrives.com/opndr.html
This should help!
Old Aug 5, 2011 | 11:02 AM
bikerlaw's Avatar
bikerlaw
Damnit man! How about some pictures!
anything2wheels
May 3, 2018 08:58 PM
Tampa Fatboy
Apr 14, 2018 11:30 PM
Hobo1979
Classic
Aug 22, 2013 06:41 PM
Kevgrowler
Jan 12, 2011 04:04 PM
robc234
Jun 24, 2009 09:10 PM
