Trans noise?
Old Sep 6, 2011 | 07:25 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by Cygnus x-1
It's a 1997 dyna wide glide. I am using what it called for in the manual. Looks like I am trans bound huh? Thanks so far for the input guys. Bob.
Don`t be in such a hurry to condemn the transmission...
Have you checked the primary chain tension?
Do you hear the noise when the bike is not moving?
Old Sep 6, 2011 | 08:05 PM
Dr.Hess's Avatar
Dr.Hess
You might get an expert to listen to it. They all make some noise. It's part of the "charm." For example, a cam gear that's too tight will make a noise that varies with engine speed, might sound like the transmission, and really means nothing at all, except the cam gear mesh could be a little looser.
Old Sep 6, 2011 | 08:51 PM
Moog Player's Avatar
Moog Player
Square gears make noise. There is probably nothing wrong.
Old Sep 7, 2011 | 03:56 AM
MaineRyder's Avatar
MaineRyder
Cygnus x-1 check your PM box
Old Sep 8, 2011 | 04:46 AM
Cygnus x-1's Avatar
Cygnus x-1
Well, for a recap and more info, while riding, noise there in every gear, higher pitched, goes away when clutch pulled in. Haven't heard it before. Primary chain is a o k. checked it the other day. Is it the possibility that when my wife and I are on it, the belt may be tightening to much and causing strain? I have my shocks lowered down to lowest setting. Just an fyi. I am going to do a solo ride when rain clears and do the pepsi challenge. If it's still there, yes I am going to have someone listen to it. Once again, thanks for all the input.
RPDLV
11
May 30, 2019 10:23 PM
01ragtop
Jun 22, 2012 10:45 AM
unfknblvbl
Dec 21, 2011 04:27 PM
sidecar91
Aug 18, 2009 10:04 AM
docksman4
Jun 29, 2007 09:39 PM
