RESTORE Engine treatment?
Old Oct 18, 2011 | 08:09 AM
hotrod351's Avatar
hotrod351
no easy fix, at least do the rings and check the valve seals, or go ahead and replace the valve seals.
Old Oct 18, 2011 | 12:57 PM
miacycles's Avatar
miacycles
The soft copper particles in RESTORE is meant for engines with babbit bearings, not engines with roller bearings. How long do you think a roller bearing will last if those particles start building up on the shafts and bearings?????? I wouldn't use it!!!! Hope this helps.
Old Oct 19, 2011 | 10:23 PM
dz1087's Avatar
dz1087
Well, I went ahead and threw a little bit in. I figure with 68k on the motor, I'm due a rebuild in 10 or 20k anyway.
Didn't think about the roller bearings, though. May be the only amount I throw in there.
fireaxxe
Feb 9, 2019 02:38 PM
bagga
EVO
31
Aug 26, 2017 08:25 AM
mtnman3
Jun 25, 2013 09:17 PM
BohnChopsInc.
Jan 26, 2009 03:36 PM
Das Mottorad
Oil Archive (no new posts)
Sep 23, 2007 08:36 AM
