Fuel Tank???
Old Jan 8, 2012 | 06:36 PM
inkslinger73's Avatar
inkslinger73
Default Fuel Tank???
Trying to find dash parts for my tank(gauge gaskets,tank panel,etc)I bought this project recently from a fella that fell on hard times and couldn't finish what he started.Anyway the tank looks like it might be off a 1999 fxr4?it has speedo and tach on tank dash,speedo cable runs through a small tube in tank into frame just under the dash.any info appreciated thanks in advance
Old Jan 8, 2012 | 11:54 PM
Kabear's Avatar
Kabear
Get a J&P Cycles Catalog. They will have most if not everything that you want.
Go up www.jpcycles.com or call 800-397-4844 and ask for a catalog. Then look through the appropriate section and see if you can locate what you are looking for.
The wiring is a little weird for the dash instruments so once you identify what you got, get a HD manual for that particular instrument panel. Ask around, for example if it matches any of my bikes I'll be glad to break the law and send you a copy of that particular page.
Heck, HD might even feel sorry for you and let you look at one of their books. Which brings up; did you talk to a local dealer or indy???
Old Jan 9, 2012 | 04:43 AM
inkslinger73
thanks I buy 90% of my stuff through jp.anyhow local dealer is not what ya would call top notch.So we will just leave that alone .thanks again
Old Jan 10, 2012 | 06:33 PM
inkslinger73
here is a pic
Old Jan 10, 2012 | 09:04 PM
EVOrider's Avatar
EVOrider
I believe in 2000, the FXR came with electronic speedometer. All previous were cable driven. Check the transmission to determine....if it has a raised hump, then it was for the 1999 model. If there is a cutout for the Speedo sensor....then it probably is for the 2000 year model.
Those two year models could be rather difficult in locating parts for. Totally different FXR's here.
1sandking1
Oct 8, 2013 02:35 PM
inkslinger73
Jan 10, 2012 06:35 PM
fighthedude
Aug 5, 2011 08:42 AM
Dynafrom818
Jul 12, 2011 08:25 PM
SeLFiSh 1
Oct 21, 2010 08:12 PM
