Do you hit the plug with the filter wrench? Can you avoid doing that? If you can avoid hitting the plug, then use what you have. You can also just pound a big screwdriver though the old filter and use that as a handle to get it loose, instead of whatever filter wrench you're using. I have just about given up on oil filter wrenches, but the band type that goes on the end of a socket works for Evo sized ones.
As for the filter itself, if every other Evo except the dyna uses the shorter filter, then I really don't see a problem with a dyna using the shorter filter. In fact, I'm surprised you can even find the longer ones chrome plated and for the dyna specifically.
If you want a better (in my opinion) filter, go to a Toyota dealer and get one for a 22R motor, like a 1986 4 cyl 2.4L Truck. If you want the longer filter, same size as what you are using now, then get the one for a LS400, (1UZFE) like for a 1999 LS400. They are already black and only about 5 bucks. Otherwise, there's only one other type of HD filter, and they fit all the Evos so it isn't a "softail only" filter.
Just want to conferm .... these filters are for Evo's ??
Yup. (This is the Evo forum, after all. I don't know nothin' about twinkies.) Look it up yourself. Go to Wix' web site, look up a filter for an Evo, look at the specs. Look up a filter for a 1986 Toyota Truck 4 cyl 2.4L (22R or 22RE motor, "E" just means fuel injected). Look at the specs. Same filter, different color paint.
I've been running them for the past 80K miles. Well, I bet a whopping 8K of that was on a HD filter, at the most. Plus 50K on the Sporty.
The 1UZFE filter (Toyota V8) is longer than the stock Evo, but those pictured above look even longer than that.
i asked a k&n rep about using the k&n 173 longer filtor on my evo and he said he did not recomend it because it had the anti drainback valve . he told me to use the 170 without the antidrainback valve.
