cam install
Old Feb 3, 2012 | 02:43 PM
JohnFlorida's Avatar
JohnFlorida
Default cam install
Just finished installing EV 27 cam . Took it out for a quick run. Runs smooth and sounds a bit throaty. Has a nice lope to it. Got a leak , looks like from the pushrod tube so I guess I squashed an o ring while installing. Gonna pop off the pushrod cover in a bit and see if thats it.
Old Feb 3, 2012 | 03:32 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I had this same problem with the upper tube o-ring. Ever since then I pull down the o-ring, make sure it is centered on the pushrod tube and then press the pushrod tube up.
Old Feb 3, 2012 | 03:52 PM
JohnFlorida
Yep thats what I figure. Last thing to do before I buttoned it up and in a hurry. I'll fix it in the morning
Old Feb 4, 2012 | 10:15 AM
JohnFlorida
got a rear pushrod leak and cant get it to stop upper o ring or might be the middle. also got 2 nosecone bolts leaking. top bolt looks like it needs a oring. Looks like its not seating. Any ideas???
Old Feb 4, 2012 | 11:20 AM
megawatt's Avatar
megawatt
If that nosecone bolt is not seating then you may have the wrong bolt in that hole.
I'm sure you noticed that the nosecone has different length bolts.
You probably switched a couple during reassembly.
Old Feb 4, 2012 | 01:18 PM
JohnFlorida
Thats what I thought but top bolts are long and lower are short. Took out the 2 leaking bolts and put a compression washer on and sealed with hi-temp gasket sealant. Waiting for it to cure right now
Doug S
EVO
14
Dec 23, 2018 12:05 PM
lhgdale
Milwaukee Eight (M8)
Dec 15, 2018 08:52 AM
Turret_plug
EVO
50
May 31, 2016 11:41 AM
2006FLST
EVO
Jun 18, 2011 10:46 PM
RudeDog
EVO
21
Feb 24, 2010 06:28 PM
