I had posted a few months back about converting my 1994 flt to an flh.
Its not too bad to do. Heres some pics.
B4
I installed a 2005 hd cd player, hogtunes ultra kit, also adding 4 channel rockford amp, powered sub, and installed polk audio seakers into the sidecar.
Progress pics;
Reason: add
I have the fairing and radio box, speakers, the guage cluster ( the 2 plugs cut off to use to splice into my new guages), the handlebars, the dual headlight set-up minus the bulb connectors (cannibalized again for the flh fe), windshield 2-3 seasons old in good shape. Also the rectangularish metal piece from frame to fairing connector, and the lower chrome pieces that bolt onto the crash bar and outside edges of the fairing, for all intents and purpose's, the whole enchilada.
I would say, 275ish and actual shiping, which would be guessing around 60-80 because of the size.
Also have brake side lower fairing with glovebox, these are removed when the dealer does the sidecar, reaally no need to keep it around.
Also the stock mufflers, which I would throw in free on the first deal, but that would probably cost 30 to ship.
