Drag pipe question?
Really cheap tube is made from a sheet of cheap steel, wrapped into a cylinder and welded along its length. It's machine made like that and will easily take the bends a Harley drag pipe needs. Better quality tube is die-formed as a tube, with no welding and will take tight bends better than the cheap stuff, but requires a decent grade of steel to form that way.
A top quality tube such as stainless steel should give a lifetime of service, and will take chrome plate very well. There are different quality levels of chrome plate, the cheaper ones being chrome on nickel, the expensive ones are chrome on nickel on copper. The finish is dependent on the polishing of the base tube and maintaining the finish at each stage of the plating process.
So there are many ways of producing a set of pipes, although finding out exactly what each brand does to make theirs may be a problem, unless they make a point of advertising what they do.
Cheap chrome won't last long before it wears through and shows the nickel underneath. It won't hold rust of the steel back for long either. Better quality tube won't rust so fast and better chrome will last longer before losing its looks. Chrome on stainless, or plain stainless, will last us all out!
Hope that helps a bit.....
If you don't mind changing pipes every few years keep buying what works for you, If you want to stop buying pipes, you will need to spend some cash.
On the subject of the washer trick I actually just ordered these below. He is a member on this site. I normally make my own washer set up so my fingers are crossed that they are worth the 22 bucks.
http://www.dkcustomproducts.com/Thunder-Torque-Inserts-118-Model-Family-DK-TTI-118.htm
