Changing spark plug wires
Old Mar 5, 2012 | 06:23 PM
Edster 69's Avatar
Edster 69
Default Changing spark plug wires
When changing spark plug wires on my 97 RK I know I have to remove my gas tank. My question is can I get away with just removing the tank bolts and lifting the front of the gas tank to get at the wires without having to disconnect wiring harnesses as well as the pet ****?? Thanks in advance!
Old Mar 5, 2012 | 06:54 PM
driv3rx's Avatar
driv3rx
i hope so thats what I planned to do wiyh my '02 RK
Old Mar 5, 2012 | 08:11 PM
EVOrider's Avatar
EVOrider
I replaced the wires on my Ultra last year or so....
I only unbolted the tank for just enough clearance to replace the wires. Tight, but the tank does not have to be removed.
Old Mar 12, 2012 | 06:48 PM
Edster 69's Avatar
Edster 69
Thanks for the advice!! Took me an hour to change out my spark plug wires! It was tight but my patience and persistence paid off! Just a heads up be careful to not disconnect the ignition switch wires as I found that out the hard way. Easy fix just had to pull the dash off and reconnect the ignition switch wires.
bigpappa160
EVO
11
Feb 23, 2016 03:17 PM
MIBPreacher
Mar 5, 2012 05:35 PM
strtarrow
Mar 3, 2011 07:59 PM
blueduramax
Jun 2, 2010 09:40 PM
avalauncher
Jul 21, 2008 09:29 AM
