The battery needs to be moved under the seat. You can use the battery box (66281-93A) used from 1993-96. If you don't also move the oil tank under the transmission, you will need to trim the box to fit using the oil tank and use a smaller battery (like the one used on a Sportster).
Originally Posted by Ultra89Rider
The battery needs to be moved under the seat. You can use the battery box used from 1994-96. If you don't also move the oil tank under the transmission, you will need to trim the box to fit using the oil tank and use a smaller battery (like the one used on a Sportster).
Thanks for the reply.
Will a side cover from a '93 fit if the oil tank is relocated?
I have done it on my 1991 FLT. Use 93-96 under seat battery tray (trimmed about an inch or so on both sides), good quality late model Sportster battery, and shorten/reroute battery cables. Used velcro strap from Lowes to fasten battery to tray. Looks like factory installation and been using for one year with no problem.
Any pics of the install? Did you change to the new bag and side cover?
Originally Posted by roach
I have just completed this mod on my 90 FLHS and did not have to change the trans or move the oil bag.
Roach
Same question. Did you change to the newer bags and side cover? If you didn't, is it in the plans?
Hey Tom,
Check this link out https://www.hdforums.com/forum/evo-cl...ocation-3.html brokeC7 did this and has some excelent pics on page 3. I am in the midle of the same swap but have been side tracked by nice weather.
Good luck hope to see some pics
