Another oil pressure question, help needed
Old Apr 23, 2012 | 07:40 PM
Spanners39's Avatar
Spanners39
I'll say it again...the breather does not affect oil pressure in any way at all......look in an Evo factory manual at the oil flow diagram....the breather allows air and oil mist into the cam chest and this means there is no effect on oil pressure.....by the time the oil reaches the breather it has exited the pressure side of the system and been splashed all over the pistons and flywheel.
Oil is pushed into the breather by crankcase pressure and exits the breather into the cam chest where it collects in a passage and is picked up by the oil pump.
If your breather was slack in the crankcases you would have increased oil consumption, smoking and a dripping or spewing breather....it would not cause the probs this bike is having which is all on the pressure side of the system which begins at the pump rotors and ends at the rocker boxes.
Old Apr 23, 2012 | 08:17 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by Joso
I am quite sure my problem is coming from the poor seal of the breather gear....
Originally Posted by jsbridgew
that's what i'm thinking
Don`t go on a wild goose chase...
Forget about the breather gear.
You need to troubleshoot the pressure side of the lube system (the breather gear is part of the scavenge side of the lube system).
Like Spanners says, look in the shop manual, read the description of the lube system and look at the diagram.
Old Apr 23, 2012 | 08:44 PM
hatchetman's Avatar
hatchetman
whats the chances the indy got 2 oil lines backwards???
Old Apr 23, 2012 | 09:43 PM
Joso's Avatar
Joso
1st Gear
Ive read the manual and studied every diagram I can find and fully understand that the breather is the return side of the system. I very much think the crankcase vacuum is leaking by the breather gear and causing a vacuum in the camchest and pulling the oil down through the clearance between tappets and tappet blocks instead of pumping into tappets and up pushrods.
Old Apr 24, 2012 | 04:49 AM
Dan89FLSTC's Avatar
Dan89FLSTC
You could connect up a giant vacuum pump to the cam chest and even then it would not affect the pressure side of the oil circuit.
But it is your bike, and you should feel free to ignore people who have been working on these things for years.
Old Apr 24, 2012 | 04:50 AM
Dan89FLSTC's Avatar
Dan89FLSTC
It would either have zero pressure or blow oil out the breather.
Old Apr 24, 2012 | 05:43 PM
Joso's Avatar
Joso
1st Gear
digging into oil pump to see whats going on, will keep posting
Old Apr 24, 2012 | 09:47 PM
pqbaker04's Avatar
pqbaker04
Stage I
Default pqbaker04
2004 FXSTBI 40,000mi .cam bearing failed .HD rebuild is replacing OEM oil pump with a scream eagle oil pump,backing plate,updated chain adjuster.Anyone else with this problem?
Old Apr 25, 2012 | 04:12 PM
Spanners39's Avatar
Spanners39
Cam bearing failure is very common on TC's.......always update ASAP if you have the spring tensioners rather than the hydraulic one.
travistodd1
Engine Mechanical Topics
Feb 14, 2014 12:40 PM
187
EVO
16
Jul 25, 2012 07:14 AM
tcfamy
Jul 30, 2009 07:49 PM
Pinex
Shovelhead
Aug 4, 2006 10:43 PM
fxdmq
Oil Archive (no new posts)
Aug 30, 2005 09:56 PM
